coilovers vs dampers
Posted: Thu Jun 03, 2004 3:18 pm
by gilmore
for improved handling and a drop of about 30mm - 35mm would a spring/damper kit from the likes of koni be ok for a Polo GTi
what are the benefits of coilovers as these are much more expensive?
Posted: Thu Jun 03, 2004 4:01 pm
by Mk4_Scotland
coilovers have the ability to adjust not just damping but also hight too, they are a bit more expensiv but a FK(adjust 20-75mm) set can be had brand new on german ebay for 400 euro, bout £270, not too bad for what they can do
Posted: Fri Jun 04, 2004 7:42 pm
by carmadaaron
coilovers are more expensive than just a spring/ dmaper kit but is worth it cus u can slam it! :wink:
Posted: Sat Jun 05, 2004 12:36 am
by Josh_PoloGTi
To be perfectly honest, a set of H&R Springs go VERY well with the OE Dampers that you already have on the car (as long as they're in good nick).
They lower the car about 35mm and make the ride and handling EXCELLENT!
Posted: Sat Jun 05, 2004 5:36 pm
by 4paws
its also a lot cheaper :D
Posted: Sun Jun 06, 2004 3:56 pm
by polopowah
i've heard lots of bad things from those budget fk coilover's, harsh ride and i dont think they are rust proof either :s , the phrase "get what you pay for" springs to mind
but if you are lowering just to -35mm then the cheaper option would be to just buy the springs and use existing dampers
-Ben-
Posted: Sun Jun 06, 2004 4:18 pm
by mk5 pimp
polopowah i see you have got spax coiloverson your car how are they and whats the ride like.
Posted: Sun Jun 06, 2004 8:57 pm
by polopowah
yeah
the ride is quite peachy at the mo, it bounces a little, but its great fun whizzing round corners low to the ground n bouncing abit 8), but it only really bounces when you either accelarate away or brake, and when you hit a bump in the road, you know about it, but its nearly on its softest setting, so i dont get back ache! it handles really well, now i've got 2 new front tyres and the tracking has been done.
Posted: Mon Jun 07, 2004 11:21 am
by gilmore
thanks guys... Josh, will these springs make the ride REALLY uncomfortable?! Also looking to change my tyres shortly as one has slow puncture and rear ones fairly low... was thinking of getting Toyo's as I only do about 6/7k a year so don't need hard wearing tyres? are these a good choice?
