Airbag Warning Light
Posted: Tue Oct 02, 2012 3:08 pm
by Yeahhluke
Hi All,
My airbag warning light is on for sme reason, has been for about a week but havent done anything with it yet, any ideas?
Re: Airbag Warning Light
Posted: Tue Oct 02, 2012 8:59 pm
by 9N3 Turbo
Best bet is to have it plugged in to find out which unit has made it come on.
Have you had the steering whelk off?
Also check both your seats to make sure those connections are ok?
Posted: Tue Oct 02, 2012 9:09 pm
by Yeahhluke
Haven't had the steering wheel off, I'll have a check round tomorrow now
Probs should have mentioned this before bit it can on after I was playing around with the fuses last week as I had to change one for a blown sidelight fuse but I thibk I pulled the wrong one out a few times?
Posted: Wed Oct 03, 2012 7:14 am
by 9N3 Turbo
Ah well in that case you'll need to plug in and remove fault code as you will have disturbed the circuit.
Easy fix of you have vagcom/faultcode reader or know someone who has.
Posted: Wed Oct 03, 2012 9:25 am
by Mr Blobby
9N3 Turbo wrote:Ah well in that case you'll need to plug in and remove fault code as you will have disturbed the circuit.
Which vagcom have you got? I need one but there are so many I dont know which ones are good...
Posted: Wed Oct 03, 2012 10:10 am
by Yeahhluke
Right ok, i think i know someone who might know someone who can do it, ill have a word and hopefully ill get it sorted this weekend
thanks for the help
