Hi Guys,
Not sure if anyone can assist. I just fitted a set of wheels and it seems to be catching on the metal wire of the brake caliper by like 1mm. Has anyone experience this before? Its aftermarket wheels.
metal wire on caliper touching mag
Re: metal wire on caliper touching mag
Sounds like you've got the wrong offset pal. What you running?
NMavs wrote:Sounds like you've got the wrong offset pal. What you running?
Sorted out bud
Good to hear bud
