Rear door seal
Posted: Sun Nov 25, 2012 7:53 pm
by BlackSEL
Has anyone experienced a door seal issue with the rear doors on their 9n3? The problem ours has is that collects water in the gap between the seal and bodywork, so holds water that then drops out when you open the door.
Tom
Re: Rear door seal
Posted: Sun Nov 25, 2012 9:27 pm
by Dom_
Mine nearside front door does this, as does the same door on my friends 9N...
Re: Rear door seal
Posted: Mon Nov 26, 2012 7:38 pm
by gti-joe
Dom_ wrote:Mine nearside front door does this, as does the same door on my friends 9N...
Mine did this also, if you went round a corner or braked hard the water would come into the cabin. Took the door card off and put a bead of silicone sealant round the joint between the door and the internal metal plate and that seemed to cure the problem.
