Brakes - 9N Upgrade to 288 and 256 rear
Posted: Tue Nov 27, 2012 8:04 am
I probally put this in wrong section before, so putting here now
I have a 2008 Bluemotion2.
I belive that means to do a 288mm conversion on the front I need
Hubs, disks, pads, carriers, caliper (and lines be nice)
Correct? What do hubs need to be off? mk4 anni ok? I presume will clear most 15's?
For the rear to disks I need a GTI rear beam basically? (I have a 225 TT with a 4 pot rear conversion so can then go to 256mm vented rear
) Will these clear 15's?
Master cylinder need changing? Is the GTI one larger bore? Anyone know what the sizes of the master cylinders are? (I cant get my Etka working on windows 7 64 bit)
I know I dont need this much braking on a pretty stock bluemotion and I will loose MPG but I want to do it. (Its booked in for a map already)
Sheldon
Sheldon
