Immobiliser Chips
Posted: Fri Feb 01, 2013 2:33 pm
by MJS_93
Does anyone know what chip is needed for 6n2's as I believe there are different types. Am I right in thinking it is an ID44 chip
Also does anyone know if you can get replacement keys made without the 'key tag' which states the key number
Re: Immobiliser Chips
Posted: Sat Feb 02, 2013 8:30 pm
by alexperkins
Hickeys.co.uk can supply the key with a blank immo chip
Audi dealers can cut the keys based on your original and VW can program them
Posted: Sat Feb 02, 2013 8:48 pm
by MJS_93
alexperkins wrote:Hickeys.co.uk can supply the key with a blank immo chip
Thanks, but it's the least of my problems at the moment as the ABS light comes on intermittently. I scanned it with VCDS Light and it has come up with the following.
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
Have you got any ideas what it could be
Posted: Sat Feb 02, 2013 9:03 pm
by alexperkins
That's the common abs pump solder joint failure
You have to remove the abs control module from the abs unit, split it and solder it back up, and seal it again.
Where are you based? I did one the other day and would happily do another if you weren't too far for beer money
Posted: Sat Feb 02, 2013 9:13 pm
by MJS_93
I'm going to see how things go with it. It's not major at the moment and too be honest I have got that much money at the moment. Do you think changing the fuses might help
Posted: Sun Feb 03, 2013 9:45 am
by alexperkins
Changing fuses won't help
One the solder joints inside the control module go the only option is to repair it.
Posted: Sun Feb 03, 2013 8:38 pm
by MJS_93
Is this what you mean
ABS pumps Solution with pics!
Posted: Sun Feb 03, 2013 9:05 pm
by alexperkins
Correct
I did that on one last week
