Polo 9n speedo problem help :(
Posted: Wed Mar 20, 2013 7:34 am
by P mk4
Drove through a large puddle on the passenger side of my car last night and my speedo has stopped working :/
Is there a sensor connected to the hub that i has stopped working ?
Any help would be appreciated as I'm suppose to be selling the car on the weekend :/
Re: Polo 9n speedo problem help :(
Posted: Wed Mar 20, 2013 9:00 pm
by 88rsr
Pretty sure the speedo takes a reading from the ABS/wheel speed sensors as when I had a fault on the other halfs car the speedo would randomly drop 10mph whilst cruising on the motorway without actually physically changing speed. Hers was solved after I ruled out the actual sensor being at fault when I replaced the wheel bearing (it has the abs pickup built into it)
Possibly the sensor has picked up some muck on it from going through the puddle giving a false or no reading. Do you know anyone with Vagcom/VCDS?
Posted: Thu Mar 21, 2013 2:39 pm
by P mk4
88rsr wrote:Pretty sure the speedo takes a reading from the ABS/wheel speed sensors as when I had a fault on the other halfs car the speedo would randomly drop 10mph whilst cruising on the motorway without actually physically changing speed. Hers was solved after I ruled out the actual sensor being at fault when I replaced the wheel bearing (it has the abs pickup built into it)
Cheers for your help i think your right as i was driving home yesterday it kicked back in. Going to get my friend to vagcom it and have a look at the hub see whats going on
