Can anyone one help P1531
Posted: Sun May 05, 2013 8:19 pm
So I have this code up booked in to my local VW garage and they refused to diagnose my problem as the car is mapped! have been looking online and code relates to the N205 valve is this a replaceable part as I can find a part number anywhere or is it part of the whole cam chain tensioner assembly.
Car runs fine btw no running lumpy or misfireing, any help whould be appreciated.
VCDS scan log below
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: *****removed***** Mileage: 65090km/40445miles
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 33278
VCID: 6DD1131627760E70FAA
WVWZZZ9NZ7Y105824 VWZ7Z0F4576390
1 Fault Found:
17939 - Camshaft Timing Adjustment
P1531 - 35-10 - Open Circuit - Intermittent
Readiness: 0010 1100
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 AT HW: 6Q0 907 379 AT
Component: ESP 8.0 front H03 0003
Revision: 00000000 Serial number: 00000000000000
Coding: 0000269
Shop #: WSC 00788 785 00200
VCID: 8F2DE99E9DBA1C60286
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: EADB980A969899481F8
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BP BN-SG. 1S34
Coding: 26030
Shop #: WSC 00788
VCID: 3C77EE522C8C57F83D4
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 16 AIRBAG VW51 0N 0009
Coding: 12598
Shop #: WSC 00788
VCID: 2C57DE12DCECC778AD4
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 923 Q
Component: KOMBIINSTRUMENT VDO V03
Coding: 01444
Shop #: WSC 00000
VCID: 41899FA64B6E3A106E2
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 01K1 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: F0EF8A62B044639851C
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER VDO V03
Coding: 01444
Shop #: WSC 00000
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 00788
VCID: 6FED091E2D7AFC60C86
Address 45: Inter. Monitor Labels: 6Q0-951-171.lbl
Part No: 6Q0 951 171 C
Component: Innenraumueberw. 0020
VCID: 326BC06AFEC89188E78
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 63 Komfortgerát 0002
Coding: 00016
Shop #: WSC 00788
VCID: 3D71E35637965EF00AA
End ---------------------------------------------------------------------
VCDS scan log below
Coding: 11500
Shop #: WSC 33278
1 Fault Found:
Coding: 0000269
Coding: 26030
Shop #: WSC 00788
1 Fault Found:
Coding: 12598
Shop #: WSC 00788
Coding: 01444
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 00788
Coding: 01444
Shop #: WSC 00000
Coding: 10120
Shop #: WSC 00788
Coding: 00016
Shop #: WSC 00788
