6n2 airbag module.
Posted: Sun May 19, 2013 8:00 pm
I have a 2001 Polo SDI which has the airbag light on since I got it last year. I checked the clock spring and that seemed OK so I took it to a man who plugged it in and it gave the following fault code:
00588 Airbag Igniter Driver Side(N95) 32-10-Resistance too high intermittent.
He tried resetting it but it stayed the same.
I then measured the resistance from the connector on the steering column, it reads about 2 ohms steady. Doesn't seem to be any seat airbags or wires coming out of the seatbelt pre tensioner.
I set about looking for the control module, I'm still looking, it isn't bolted to the floor under the centre console, not behind the passenger dash, not next to the accelerator, not anywhere it says to look on the internet. Most of the trim is out and I still haven't found it.
Any help would be appreciated, car's too good to scrap for the sake of a light.
