UK-POLOS.NET - THE VW Polo Forum • Quick Answer : Remove Rear Seats on 9n3
Page 1 of 2
Posted: Tue Jul 23, 2013 6:03 pm
by Tony Boi 92
Hi guys
Does anyone know how to remove the back bench on the 9n3
Tony
Re: Quick Answer : Remove Rear Seats on 9n3
Posted: Tue Jul 23, 2013 6:29 pm
by Ben90
Fold the rear bench down, in either far corner you'll see a metal latch with a 5mm notch in it, you use a screwdriver or similar in the notch to push the latch which releases the seat bar and lifts it up. Then slide the seat out of the other side. Repeat for the other side of the bench. HTH
Posted: Tue Jul 23, 2013 6:45 pm
by blazeguarder
And the bit you sit on is just hooked onto the floor. Fold the seat bases forwards and you'll see the metal hanger hooked into some loops which can be easily unhooked and removed.
Posted: Tue Jul 23, 2013 7:47 pm
by Tony Boi 92
Solved
Thanks guys
Was pushing the latch back but wasnt sure what to do about the bit that sticks out!
Thanks again
Posted: Tue Jul 23, 2013 8:03 pm
by andyc315
Posted: Tue Jul 23, 2013 10:21 pm
by Tony Boi 92
andyc315 wrote:Image
Racecar y0
Posted: Wed Jul 24, 2013 9:39 pm
by andyc315
just had a prod around my rear seats as you do :|
i see the 5mm notches, then what do you do with them :lol: prodded them with my key and they seemed pretty stiff so left them alone for now :roll:
Posted: Wed Jul 24, 2013 9:44 pm
by Ben90
Push them (either forward or back) and the latch that the notch is in will retract and lift out the backrest rod at the same time, which can then be lifted out. don't worry it's sturdy!
Posted: Wed Jul 24, 2013 10:19 pm
by andyc315
Ben90 wrote:Push them (either forward or back) and the latch that the notch is in will retract and lift out the backrest rod at the same time, which can then be lifted out. don't worry it's sturdy!
cheers, will have a better go tomorrow!
going on a 1000 mile road trip round scotland with camping gear so want as much room and little weight as possible haha
Posted: Thu Jul 25, 2013 7:23 am
by Tony Boi 92
Come on Andy aint hard ...
:roll:
Posted: Wed Jul 31, 2013 9:35 am
by andyc315
That latch... if you push it all the way back to get the bench out, if you wanted to put the seats back in how do you get the latch back out of the recess? Looks like it is going to disappear and a screwdriver can't pull it out :smile:
Sent from my GT-I9100P using Tapatalk 2
Posted: Wed Jul 31, 2013 10:05 am
by Tony Boi 92
andyc315 wrote:That latch... if you push it all the way back to get the bench out, if you wanted to put the seats back in how do you get the latch back out of the recess? Looks like it is going to disappear and a screwdriver can't pull it out :smile:
When you put the bench back in, as the knob bit goes in, it will pull the latch back over it
Dont worry about that man(Y)
Posted: Wed Jul 31, 2013 10:13 am
by andyc315
Thought it might but with my luck with f*****g about with cars it would never be seen again!
Getting a bonnet bra for £22.50, don't shoot me :-P
Posted: Wed Jul 31, 2013 10:39 am
by Tony Boi 92
andyc315 wrote:Thought it might but with my luck with f*****g about with cars it would never be seen again!
Na its all good man ;)
Not impressed
LOL
Posted: Mon Sep 09, 2013 3:35 pm
by andyc315
just weighed the rear seats, middle seatbelt buckles, boot carpet and parcel shelf and they weigh a combined 29.5kg :shock: :shock:
