Polo 6R - Useful Part Numbers
yeah just get the BlueGT spoiler
Noiseprojekt
Drives: VW Polo -14 1,2 TSI R-Line
Post by Noiseprojekt »
iichel wrote: Tue May 17, 2022 11:12 am yeah just get the BlueGT spoiler
Wow, thanks!
I did not know that them existed!
Now i just got to find the part number
EDIT:
53 Left 6R6805945
54 Right 6R6805946
But i dont know if you'll need part 51, 6R6827989 "Bracket for spoiler" as well
Does anyone know what these clips are called?
The EGT wire clips into it on the turbo housing. It seems that KK3 dont fit on 1549vz 🤔
Can someone tell me what is the part number of terminal pins (male and female) for rear door connector ( 1K0 937 702 C) ?
MCP 2.8 and MCP 1.5
Thank you!
wolfie
Drives: 6R1-1.2 TSI (2011, CBZB, 77Kw, 35Kmiles)
Post by wolfie »
In the past if I've wanted part number info I've used the parts catalogs on 7zap.com. They've generally been very good. However they appear to have updated the site and now it's a complete dogs dinner. Really struggling to use it now.
Where else can you gain access to VW part numbers??
wolfie wrote: Sat Feb 25, 2023 2:04 pm In the past if I've wanted part number info I've used the parts catalogs on 7zap.com. They've generally been very good. However they appear to have updated the site and now it's a complete dogs dinner. Really struggling to use it now.
Try this;
https://webautocats.com/en-gb/etka/volkswagen/
wolfie
Post by wolfie »
Cheers that was quick... :D
Thanks for the link.
Cruzor
Drives: VENTO 1.5TDI
Post by Cruzor »
1.Hi, does anybody know the part number for this beige trim piece? It’s also available in black which is what I’m looking for. I checked in ifinterface but it shows only the smaller fuse box door(you can see it’s a separate piece) in the diagram, so I’m asking here. Is this even removable?
Edit- 2. Also If someone can share the terminals and block part numbers needed for an 654 g85 steering sensor it’d be fantastic.
the lower dash trim is not a separate part
G85 is connected to the T41 connector of the slip ring, those are all MQS
Cruzor
Post by Cruzor »
Thank you for the help. Ahh that’s a bummer, I found a black glovebox for cheap and thought to make the whole dash black :|
