UK-POLOS.NET - THE VW Polo Forum • knocking from passengers side
Posted: Tue Sep 24, 2013 7:37 pm
by cam20vt
Hopefully someone could shed some light for me, my 08 gti has a knocking when setting off and sometimes over speed bumps or if I accidently hit a pothole (easily done where I live) , its coming from the passengers side but I cant pin point where its coming from, the car had a new gearbox mount and engine mount when I did clutch (about 2 month ago) as there was play and the engine mounting snapped about 3 week ago but its still knocking, ive checked everything I can think of and cannot find play in anything, it knocks 3 or 4 times when setting off normally and sometimes when I change into 2nd and put accelerator back on as normal any help will be much appreciated
Re: knocking from passengers side
Posted: Wed Sep 25, 2013 12:59 am
by Dom_
Check subframe bolts and lower arm bolts, mine were ever so slightly loose and made an awful noise when setting off
Did you change the dogbone mount too?
Posted: Wed Sep 25, 2013 3:52 pm
by cam20vt
No the dogbone mount seemed fine when it was removed, might change just to see if it makes a difference, will check subframe bolts as soon as I get a minute, yeh its a really loud knocking when setting off, not sure how to put videos up ive got one of it knocking
Posted: Wed Sep 25, 2013 6:53 pm
by Dom_
Sounds a lot like what mine was doing, the bolt was on a little loose but the lower arm was moving and the noise was transferring through the whole subframe making it sound really violent
Posted: Thu Sep 26, 2013 3:55 pm
by cam20vt
Checked all the subframe bolts, not a bit of movement in any bolt all tight but still the same knocking
Posted: Thu Sep 26, 2013 6:01 pm
by GTi_Red
You got a cone filter on it?
Posted: Thu Sep 26, 2013 11:37 pm
by cam20vt
No its got a foam ramair airfilter, thought it could be the base of that banging on the airbox so I removed the air box and made sure the filter was secured in place it sounds like a bush or mounting when it knocks, its really loud and easily noticeable when setting off but when its on the ramp I cant find anything at all with play its driving me mad
Posted: Fri Sep 27, 2013 6:55 am
by Stargazer
Have you checked the dog bone mount bolt? Mine was about 1/4 turn loose and sounded like the car was gonna fall apart lol
Posted: Fri Sep 27, 2013 9:36 am
by cam20vt
Yeh ive checked then bolts aswel, gonna order the dogbone mount today, one less thing it could be then
Posted: Fri Sep 27, 2013 6:09 pm
by GTi_Red
Bush mount bolts?
Posted: Fri Sep 27, 2013 7:06 pm
by cam20vt
Yeh I checked the dogbone bush mount bolts they were tight and I know the engine mount bolts are tight as I did that one gonna take battery out tommorrow and check the upper gearbox mount bolts
Posted: Sun Sep 29, 2013 11:24 am
by cam20vt
The upper gearbox mount bolts had come ever so slightly loose, either that or the mechanic didnt tighten them properly
