G60 front discs on 6n2 Gti Polo
Posted: Sun Oct 27, 2013 6:08 pm
by frankoni
Hi all, I've decided that as I'm replacing the front discs on my Polo Gti 6n2 that I'm going to use the G60 discs. I've already bought new G60 caliper carriers, my question is what pads will I need?? Will the Corrado G60 ones fit once the disc is in place?? I noticed that the thickness of the Corrado pads are 2mm thicker than the Polo Gti ones.......
Re: G60 front discs on 6n2 Gti Polo
Posted: Sun Oct 27, 2013 6:27 pm
by alexperkins
You'll need to use GTI pads however you may need to shave the backing down a little on the edges as sometimes they foul the carrier.
Once the discs are worn down a bit you can fit G60 pads in, but not before unless you use g60 calipers
Posted: Sun Oct 27, 2013 7:13 pm
by frankoni
cheers for the reply.....
is this a worthwhile upgrade ?? ive already bought the caliper carriers.....
Posted: Sun Oct 27, 2013 8:04 pm
by alexperkins
Yes I'd say so. I've done it on the two gtis I've had.
Posted: Sun Oct 27, 2013 8:18 pm
by frankoni
When you say 'shave the backing down ' do you mean the actual back or the edges??
Posted: Sun Oct 27, 2013 11:56 pm
by alexperkins
The edges. The pads are too wide
Posted: Mon Oct 28, 2013 12:04 am
by frankoni
ahh right ,i get what your saying.....thanks for your help, im going to order the parts now.
