UK-POLOS.NET - THE VW Polo Forum • Gear shift knob removal
Page 1 of 2
Posted: Wed Feb 05, 2014 7:33 pm
by Raptor1
Hi Guys! Doew anybody know how to remove the gear shift knob from our 6rs? I tried to reach the clips by selecting 3rd gear and using my thumbs but without any luck.Should i use a trim removal tool? I'm afraid of braking any clips or scratching the silver trim at the base of the shift knob.
Re: Gear shift knob removal
Posted: Thu Feb 06, 2014 1:44 pm
by Raptor1
Anyone?
Posted: Thu Feb 06, 2014 5:59 pm
by grem
you can use a trim removal tool or an old store card to pry the trim around the gear sticks boot open. Once its out you can turn it inside out and lift it over the knob and you will then be able to undo the knob from underneath the leather.
Its a really easy job but removing the trim can be worrying as it often takes quite a bit of strength to get it to pop off.
Just be careful and take your time, should be fine
Posted: Mon Feb 10, 2014 2:06 pm
by Raptor1
So,I've removed the knob with the leather but i cannot figure out how to seperate the knob from it.Any ideas?
Posted: Mon Feb 10, 2014 3:48 pm
by grem
It should be very simple and you should be able to see what to do. Show me a picture and Ill see if its the same as mine?
Posted: Mon Feb 10, 2014 5:03 pm
by Raptor1
Posted: Tue Feb 11, 2014 9:56 am
by Raptor1
Any ideas? Even at the service they didn't know how to do that :/
Lumia 820
Posted: Tue Feb 11, 2014 3:32 pm
by ciclo
This is the usual way to disassemble but you have to be careful and watch carefully in the specific shape of your knob.
Examples: white Polo 6R, black Audi A1
The service manual does not provide a process for dismantling leather boot.
Posted: Tue Feb 11, 2014 3:36 pm
by Raptor1
On the last photo,that's exactly the swap i'm trying to do.But polo's plastic ring even cracked a little bit .So i guess i'll order another gaiter in order to fit the a1 knob on it.
Posted: Tue Feb 11, 2014 3:53 pm
by ciclo
In this link you have another way to do it (Polo 6R-A1). Is the french forum and registration is required.
http://www.polo6r.fr/t10534-tuto-instal ... au+vitesse
Posted: Tue Feb 11, 2014 9:30 pm
by grem
Raptor1 wrote:On the last photo,that's exactly the swap i'm trying to do.But polo's plastic ring even cracked a little bit .So i guess i'll order another gaiter in order to fit the a1 knob on it.
what is the swap you ar doing, can I see a photo of the kob as im looking to change mine again as I dont like it
also @ciclo be carfeul with the ring, mine could slide up by hand. If your going to use a screwdriver make sure you use it all the way around not just on one side or it can snap the plastic clips on the inside off
Posted: Tue Feb 11, 2014 10:28 pm
by Raptor1
I'm trying to get rid of the standard knob and put on the knob from an A1.The best way to do it is the one shown in the French forum and it also requires a lot of time.But I've found out that if you choose to use a screwdriver to unclip the black plastic ring,it is very possible that you'll break something.
Lumia 820
Posted: Wed Feb 12, 2014 2:50 pm
by Raptor1
So,i've tried literally everything but i cannot get it done even with the ''French'' way without doing any damage.
So i'm trying to find the part number of the gaiter now. :( :cry:
Posted: Wed Feb 12, 2014 4:51 pm
by ciclo
Posted: Thu Feb 13, 2014 4:47 pm
by Raptor1
I managed to finally separate the original knob from the leather and here are the results:
