Remap with New *Laws*
Posted: Tue Mar 04, 2014 8:39 pm
by S_evans91
Hi all
I'm new on here but with the law just changing to make a check for a DPF on all MOTs compulsory.
Could I still get my 1.6 tdi 90ps remapped or is this no longer an option.
Please get back to me and let me know.
Thanks.
Re: Remap with New *Laws*
Posted: Tue Mar 04, 2014 11:13 pm
by ben4012
You can have a map which keeps the DPF.
Posted: Wed Mar 05, 2014 1:15 pm
by S_evans91
Brilliant. thank you. do you have any recommended places to go for it?
Posted: Thu Mar 06, 2014 6:35 am
by chrispy.
Pendle Performance
Very good company who care about getting a smooth power line to reduce a huge spike in power which can result is burning your clutch out.
Posted: Thu Mar 06, 2014 3:54 pm
by joelburbidge
The mot check for dpf is only a visual check so you can have the filter taken out on the inside and the casing put back on I believe
Posted: Thu Mar 06, 2014 10:59 pm
by greypolo9n3
I think joel is right..
as there is no real way of actually checking if there is a filter inside...Unless they use the vagcom feature which i dont think they will bother with
But its 99% most likely to just be a visual thing..ive had my dpf and cat removed but "visually" they are still there
Posted: Fri Mar 07, 2014 7:01 pm
by S_evans91
Would they not be able to tell when they do the emissions test?
Posted: Sat Mar 08, 2014 12:29 am
by joelburbidge
I believe they don't emission test diesels
Posted: Sun Mar 09, 2014 8:44 am
by greypolo9n3
they do emission test diesels..
but even all this does not hugely impact a diesel....80% of the time it passes it
Or just have a friend for an MOT tester....
