Help needed urgent :(
Posted: Sat Apr 12, 2014 4:28 pm
by helloimjammie
Neither of my side lights are working, tried changing the bulbs and still nothing?
Could it be a possible blown fuse?
If so does anyone know which fuse it is?
Re: Help needed urgent :(
Posted: Sat Apr 12, 2014 5:03 pm
by ben4012
Posted: Sat Apr 12, 2014 5:52 pm
by helloimjammie
I used this layout and it was fuse 21 a 10 amp mini blade fuse!
My interior lights didn't work, neither did front or rear sidelights, and this sorted them all out!
Posted: Mon Apr 14, 2014 4:09 pm
by Raptor1
If i disconnect the no.56 fuse in order to switch off the daytime running lights (1.2 tsi sel) will there be any problem? Do i have to do something else via VCDS or any chance of an error on the instrument cluster?
Posted: Mon Apr 14, 2014 5:22 pm
by helloimjammie
I did this today
http://www.uk-polos.net/view ... hp?t=57668
Still left with side lights as DRL but looks better than having dipped beam!
You can always try and put no 56 but be sure to check everything else works? I've never tried this so I can't comment but give it a try
