MOT failures
Posted: Wed Sep 24, 2014 3:37 pm
by fabster
Hi Guys
My 2008 1.2 Polo has failed it's MOT and I've been quoted the following:
1) Rack GAITER - O/S gaiter insecure - £111.97
2) N/S/F lower suspension arm bushes deteriorated causing excess movement - £172.57
2) O/S/F lower suspension arm bushes deteriorated causing excess movement - £172.57
Are these faults common and are the quotes reasonable?
Any help appreciated.
Re: MOT failures
Posted: Wed Sep 24, 2014 5:13 pm
by alexperkins
That seems alot of money to fix the rack gaiter
The bushes are a common failure point on these - that seems reasonable.
Re: MOT failures
Posted: Wed Sep 24, 2014 8:12 pm
by RUM4MO
Tut, Tut, I'm guessing that you just stick the car in a "hope" - no periodic servicing that should have spotted that? My wife's late 2002 1.4 SE with 102K miles only got a couple of advisories, ARB mounting bushes looking a bit old, and a rear box that might have a slight gas leak!
Re: MOT failures
Posted: Wed Sep 24, 2014 10:13 pm
by fabster
It has an annual service which is done in October of every year even though the car only does school runs.
Re: MOT failures
Posted: Thu Sep 25, 2014 7:22 pm
by RUM4MO
alexperkins wrote:That seems alot of money to fix the rack gaiter
I agree, maybe ask politely for a breakdown of costs for that job. From the description, the least that needs doing is buying and fitting new clamps for the gaiter - most per side should be, remove TRE, remove track rod locking nut, remove gaiter clamps, remove gaiter, fit new gaitor, secure it with two new clamps, refit track rod locking nut, refit TRE probably using new nut if it has been removed from the hub assembly, check/adjust tracking.
Consider getting Seat Cupra lower bushes unless you trust the revamped standard version - don't dismiss using the Seat Cupra "go-faster" bushes as they are "last for ever" bushes, well the ones on wife's 2002 Polo have been on for 7 years and are still as good as new!
Re: MOT failures
Posted: Thu Sep 25, 2014 7:29 pm
by RUM4MO
fabster wrote:It has an annual service which is done in October of every year even though the car only does school runs.
Ah, at the age that car is now, consider getting the servicing done prior to the MOT.
Re: MOT failures
Posted: Thu Sep 25, 2014 8:43 pm
by fabster
RUM4MO wrote:fabster wrote:It has an annual service which is done in October of every year even though the car only does school runs.
I think that's probably a good idea.
Re the MOT, I took the car to a local independent garage who failed on just the offside bush - they are charging £7 for the part and £55 for labour. Quite a difference!!
Thanks for your advice guys.
Re: MOT failures
Posted: Sun Sep 28, 2014 5:35 pm
by ryanday91
fabster wrote:Hi Guys
is that at a main dealer?
get prices elsewhere.
i could do all of that for £200! including the mot!
