Do the new style of sports pedals fit the 6R?
Posted: Fri Feb 27, 2015 3:52 pm
by MattS
I've seen that there's a new style of metal pedals for the 6C, they have larger black areas than those available on the 6R, does anyone know if they would fit on a 6R?
Thanks!
Re: Do the new style of sports pedals fit the 6R?
Posted: Fri Feb 27, 2015 4:52 pm
by iichel
If I remember correctly, the clutch and brake will fit but the throttle is a bit different. You could check out ciclo's Polo build thread since he did a retrofit.
Posted: Fri Feb 27, 2015 5:10 pm
by beatty599
Posted: Fri Feb 27, 2015 7:34 pm
by ciclo
Failure
http://www.uk-polos.net/view ... 30#p480972
Solution
http://www.uk-polos.net/view ... 25#p484325
Proof
http://www.uk-polos.net/view ... 72#p485572
I can assure that in this way assembly is perfect, and I think that is the only way to assemble 6C new style pedal caps (the only ones that it sell) on 6R without breaking anything. :)
Posted: Tue Mar 03, 2015 11:09 am
by MattS
iichel, beatty and ciclo, thanks so much for your replies! :D
