cant open the boot
Posted: Wed Mar 04, 2015 9:56 pm
by rbrstr
im new to this forum, ive joined because ive just bought my 17 year old son his first car, a 1.4 polo.
It has a few issues with the electric windows but the problem i need help with is that i cannot open the boot! it was open in the ebay pictures so we didnt even notice until we'd got it home, is this a typical polo issue?
also, it only came with 1 key, does the 1.4 16v on a Y plate not have remote CL?
thanks in advance for any info
Re: cant open the boot
Posted: Wed Mar 04, 2015 10:48 pm
by alexperkins
Depends what trim level.
E and Match are manual locking
S has central locking
SE has remote central locking
When you turn the key in the boot what happens? How does the handle feel?
Posted: Wed Mar 04, 2015 11:18 pm
by rbrstr
nothing happens when i put the key in the boot lock, it turns left and right but nothing happens. the CL isnt working on the doors either
Posted: Wed Mar 04, 2015 11:31 pm
by alexperkins
Guessing regardless of where the key is, the handle does nothing?
Its worth checking the central locking pump in the boot behind the drivers side rear light cluster
Posted: Thu Mar 05, 2015 8:04 am
by rbrstr
Right I'll check that, thank you very much
Posted: Thu Mar 05, 2015 7:18 pm
by rbrstr
does anyone know if there are there any old posts/threads about servicing or repairing these pumps?
Posted: Thu Mar 05, 2015 10:04 pm
by 937carrera
Posted: Fri Mar 06, 2015 7:10 pm
by rbrstr
so i climbed into the boot through the rear seats and fairly easily flicked the locking lever over with a screwdriver and can now open and close the boot, but now when i put the key in the boot lock it will not turn in either direction so i now cant lock the boot! ive located the vacuumn pump and its not working despite looking to be in as new condition when i disassembled it, so i will replace this.
i did notice when i blow and suck on the disconnected blue pipe i cant lock and unlock the fuel cap, but it doesnt operate the door locks, is this normal does anyone know?
many thanks
Posted: Fri Dec 11, 2015 6:01 pm
by Polo_Guy
i have the same problem with mine its a 1.4 16v se and i can't open the boot, i can't even turn the key for the boot
Posted: Sat Dec 12, 2015 10:04 pm
by alexperkins
You might have to remove the boot panel inside to get the lock to release manually
