New GTI Help
Posted: Sat Apr 04, 2015 4:57 pm
by Stugolf1
Hi guys
Recently picked up a lovely Polo GTI 1.8t from a forum member, 2 issues if anyone can help
Firstly there is a knock underneath, it's only happening over bad roads but I can feel it a bit through the steering, the wishbone bushes have been replaced by the previous owner so I'm not suspecting them, it does feel like something loose but the weather been so bad I can't check yet
Secondly, it might just be me being a bit panicky but there seems a whine on the gearbox which is a lit louder than I was expecting, it only happens in first gear and only between 2-2.5k revs it then disappears and doesn't occur in any other gear, anything to be worried about?
Cheers Stu
Re: New GTI Help
Posted: Sat Apr 04, 2015 7:49 pm
by Stugolf1
Basically I've found a video of the noise I have on the gearbox on YouTube, it you listen in to when the car starts you hear the gearbox whine at 2k
https://m.youtube.com/watch?v=7LHkHvc1ZQI
Re: New GTI Help
Posted: Mon Apr 13, 2015 11:18 am
by Stugolf1
Anyone?
Re: New GTI Help
Posted: Mon Apr 13, 2015 11:32 am
by alexperkins
1st gear can sometimes whine due to the synchros on 1st and 2nd gears - i wouldnt say its anything to worry about if it sounds like that video
As for your knock, it could be top mounts, tie rods, drop links, engine mounts, wishbone bushes. Really needs some investigation to check for worn or broken parts.
Re: New GTI Help
Posted: Mon Apr 13, 2015 12:15 pm
by Stugolf1
Thanks Alex
Yes the suspension has been diagnosed as a top mount issue which is being fixed, I was just a little worried about the noise in 1st Gear but it its reasonably common that puts my mind at ease
