Misfiring & limp mode
Posted: Mon May 04, 2015 4:09 pm
Changed the spark plugs couple days back whilst doing an oil change service.. Drove the car and it was fine.. Running smooth!
Finished up and then headed out about 30 mins after doing the service.. and the car misfired whilst accelerating. It then bleeped and the EPC, Check Engine and Traction Control warning lights turned on.
Took the plugs out thinking they were the wrong ones, and they appeared shorter than the older ones - so we placed the old ones back in but still the car wont like it.
From Idle to 2000rpm.. The engine will be misfiring.. But on higher revs, it runs fine.
Ran VCDS Diasgnostics and it brought up the following : (see attached pictures)
Any ideas?
Any ideas?
