UK-POLOS.NET - THE VW Polo Forum • Second/central trunk light - where to connect the wires?
Posted: Thu Jul 23, 2015 8:45 am
by CNK
Hello,
I try to do additional trunk lights (like ciclo), but I don't know, where I should connect wires from lights?
Ciclo's intstruction: https://drive.google.com/file/d/0B2nv91 ... FTMFk/view
Where I should connect the beam to the red-black cable?
Do I need to connect one cable to the T5h on the left and the other to connector on the right side of the trunk?
I found these some pictures:
http://forums.tdiclub.com/showthread.php?t=358501
http://forums.vwvortex.com/showthread.p ... ts-our-car
Is there a better way to connect wires?
Regards
Re: Second/central trunk light - where to connect the wires?
Posted: Thu Jul 23, 2015 5:59 pm
by Mart!n-GTI-DK
The easiest way wuld be to just solder the wires to the wires going to the original trunklight...
Posted: Mon Sep 07, 2015 12:55 pm
by Andrea 6r
Hello
I connected a wire to the red and blue and I added mass to the "hub" that is also seen in pictures ...
But the light bulb does not work and I remain on the interior lights
where did I go wrong? :cry:
Posted: Mon Sep 07, 2015 1:11 pm
by iichel
the 'mass' wire is T5h/1
the other wire is a PLUS :-)
Posted: Mon Sep 07, 2015 1:18 pm
by Andrea 6r
https://www.youtube.com/watch?v=4iXzCKi9e3E
So what do I connect? :shock:
current,the + 30, from where I take? :shock:
Posted: Mon Sep 07, 2015 2:22 pm
by iichel
most ideal would be a terminal 30 +12V. always fused.
if i remember correctly, you have a fuse box for your folding mirros. you can maybe take a wire from that fuse installation and guide it to the rear.
so the positive (terminal 30) goes to one wire, the other wire to T5h/1
then it will work :)
Posted: Mon Sep 07, 2015 4:35 pm
by Andrea 6r
in the end I got it from red / black that is there in the area
It should be the ceiling, so "perfect"
Posted: Wed Sep 09, 2015 4:05 pm
by Ugabista
Andrea 6r wrote:in the end I got it from red / black that is there in the area
Hi Andrea 6R, then where you connect exactly 2 wires the new lamp?
Tell me in words rights, not pictures [emoji3]
Posted: Wed Sep 09, 2015 4:49 pm
by Andrea 6r
hello, mass, I connected to the red wire and blue
the current, I got it, the red and black wire that goes up into the sky
Posted: Wed Sep 09, 2015 7:06 pm
by ciclo
If you want the second trunk light works like the original light and it is protected by the same fuse:
+ hook the positive wire (2) to pin number 2 of the original light
- hook the ground wire (1) to the red-blue cable (shown in the above picture)
Or if you prefer hook the two wires to the two wires original trunk light. As it has been said earlier.
Come on! it is easy.
Posted: Wed Sep 09, 2015 7:55 pm
by Ugabista
Okay, simple, just give work :)
I was playing as Andrea 6R
Andrea 6r wrote:Hello
One day I make this mod. :wink:
