vcds autoscan
sanders
Drives: 6r bluemotion tdi 1.2
vcds autoscan
Post by sanders »
hi ciclo,
here is the vcds log from my 6r. could you take a look and see if my coding for the autolight is correct. i had copy/paste it could not do a attachment :roll:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6RZCY2
37-Navigation -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2 DCM3.7 H07 9707
Revision: 12005001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM12TDI03103P906021B 001036
ROD: EV_ECM12TDI03103P906021B.rod
VCID: 275B8BDE5E9A7E26FA7-8072
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210224E3416E00B7842624E282D900521300
Shop #: WSC 00788 648 00255
VCID: 800970421774E91E1BD-80D5
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387958A28B24E1DE63D-806D
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 026120185
Coding: 3AB02BBF08F32400B3380FB06EAB0ED95F80612F7E862441200000000000
VCID: 418F3546D8FEA016D43-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 270812 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 58BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 020000
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 58BC32
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX013PB9F
Coding: 003232
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9D126AEDC8634E059-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405515IRQ4PI+
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405115IRQ6G4H
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB404R12QE4FGAU
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405N12QE41941
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H04 0206
Serial number: 00000010431041
Coding: 140A01
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
VCID: 3A7D42AABD28F3CE959-806F
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0035
Revision: H38 Serial number: 010212F1002792
Coding: 2500C2
VCID: 34616C92974C05BE4F5-8061
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 183999 km
Time Indication: 0
Date: 2041.14.05
Time: 14:26:28
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H04 0014
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25_SK25.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661806871
Coding: 020000
VCID: 295F8DE6408E4856EC3-807C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 H HW: 1T0 035 680 F
Component: RNS-MID H61 4120
Revision: AB001001 Serial number:
Coding: 00000400000000010001
Shop #: WSC 12345 123 12345
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6B63FEEA6A2666327-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0035
Coding: 030B1A59
VCID: F4E12C9257CCC5BE0F5-80A1
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 F HW: 5K0 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661870876
Coding: 0800000000000210
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 285988E25384715EF3D-807D
End ---------------------------------------------------------------------
Re: vcds autoscan
My reply Image
sanders
Re: vcds autoscan
Post by sanders »
thanks :wink: :wink:
Re: vcds autoscan
AL & CH/LH
RLS, OK
BCM, OK...
Current coding: 3AB02BBF08F32400B3380FB06EAB0ED95F80612F7E862441200000000000
New coding: 3AB02BBF08F32400B3380FB06EEB0ED95F80612F7E862441200000000000
Change Byte 13 bit6; without this change, Automatic Lights and CH/LH (fog lights) also should work, so you should check that the relays are working properly.
Put your hand on the relays, you should notice a little bump when are activated. (checking one by one , interchange them over adapter)
sanders
Re: vcds autoscan
Post by sanders »
Hi ciclo,
Thanks for your reply. Relays are working when switched from auto to headlight the relay clicks. Relay fog light doesn't click when pulling the switch to the fog position.
Swopped relays from fog to headlight to see of the relay from the fog light is broken, but it works in the headlight position.
I will change the coding to see of it work
Greetz
Re: vcds autoscan
It would be the first time I hear that a new light switch does not work properly (if possible, make tests with another switch), but I fear you'll have to check your wiring.
In this case the best is remove the wiring and check with the multimeter.
sanders
Re: vcds autoscan
Post by sanders »
the switch came with the rain/light sensor and rearviewmirror mod. from china.
i will order a new switch and remove the wiring and measure. still strange that the auto light don't work. the light sensor that i installed seems to work , last week i saw that the rns changed from daylight thru night color when i drove through a tunnel :D .
anyway Ciclo thanks for your help at this point. i'll keep posting here about my progress.
Re: vcds autoscan
Before buying a new switch you should check the wiring. :|
Your Bluemotion not need the cable in T17/3 original slot for DRL.
You have fog lights and daytime running lights factory, right? If so, you do not need to add any wires in the original wiring.
According to Elsawin DRL and front fog light can be installed in different ways, but depends on Polo 6R model, equipment, ....
Check the wiring you've made, every position from 10-pin connector to other connectors, or relays adapter.
Also check that all the pins on the red connector are hooked firmly, sometimes they loosen by having the tabs too inward (after handling from the original connector).
sanders
Re: vcds autoscan
Post by sanders »
think it's the best way, hope i have the time next weekend then i will remove the wiring and start over :?
first measure it before i take it apart :mrgreen:
thanks ciclo
sanders
Re: vcds autoscan
Post by sanders »
An update,
Removed the wiring and rewired it again. Everything works now. Must have crossed some wiring along the way [SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES][SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES][SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES]
Verstuurd vanaf mijn GT-I9505 met Tapatalk
Re: vcds autoscan
Cool! :wink:
