3rd Time unlucky...
Posted: Wed Jul 28, 2004 2:24 pm
by Karl_CLCoupe
I've not had much luck with the CL - GT clocks conversion. I'm now 3 sets of clocks down the road, and all of them do the same thing. I'm stuck for straight forward options now :( . Unless I can get hold of some late spec GT clocks from a '93 model. Failing that I wonder how easy it is to go after market and get something like a TIM one. I have no idea how to wire these up though, but anything to get a rev counter in the thing.
Karl.
Posted: Wed Jul 28, 2004 3:22 pm
by deadcat
does the rev counter just fit where the clock was or is there some new fancy wiring thing.. ?
I mean, if you unplug the clock from the circuit board will a rev counter just fit in the holes and work?
if it does you could put your old clocks back in, but just slot in the rev counter instead of the clock....
just a thought...
Posted: Wed Jul 28, 2004 11:30 pm
by DanW
deadcat wrote:does the rev counter just fit where the clock was or is there some new fancy wiring thing.. ?
just a thought...
I sold him the rev counter for the exact solution, but it seems it doesn't work properly as there isn't the holes on it.
Have u tried genesis clocks yet?
Posted: Thu Jul 29, 2004 12:27 am
by toXXin
What's the problem with it? Is the rev counter not working?
If so, wrighty had the same problem on his white '93 CL. I'm sure he had to have a wire redone to get it working...possibly one that goes into the coil?
Posted: Thu Jul 29, 2004 5:53 am
by tarquin bevilastard
toXXin wrote:What's the problem with it? Is the rev counter not working?
we had to do this when putting those clocks on our mk3 dash conversions into mk 2s , perhaps on the mk3 cl the same applies :D
Posted: Thu Jul 29, 2004 10:28 am
by GroovyCarrot
Ooh, you managed to do that? How easy was it to do?
Karl, I'll keep a lookout in the scrappies around here for late GTs for you.
Posted: Thu Jul 29, 2004 12:59 pm
by Karl_CLCoupe
Thanks everyone.
@deadcat: Unfortunately its not as simple as that, as the circuitry to support a rev counter is different to a clock. The rev counter did work, its just I'm still having problems with the oil pressure light and buzzer going off above 2k rpm, when my standard clocks don't do a thing.
@DanW: This last set were Genesis clocks I bought off D4VID. I thought trying Genesis ones would make a difference, but instead I just learnt that they are one and the same set of clocks.
@tarquin_bevilastard: What wire was it you had to modify?
@Groovy_Carrot: Thanks :D
I'm still exploring the possibility of aftermarket dash mounted rev counters. Apparently there are four wires to attach. It can't be too hard can it?
Karl.
Posted: Thu Jul 29, 2004 1:05 pm
by GroovyCarrot
Well, easy enough if you can find the wires to connect it to, you can find them on the connector leading to your current dashboard.. personally I far prefer built in rev counters, always thing that dashmount ones look a bit dodgy, plus they tend to be vastly expensive for what they are.. but that's just my thoughts on it :) I'm sure you'll be able to modify a standard set though.
Posted: Thu Jul 29, 2004 1:10 pm
by Karl_CLCoupe
I hope so. I think the problem lies with what Gareth_GT_Hatch identified: The fact I only have one oil pressure sensor on my car, and the fact that GT clocks rely on 2. I wish VW hadn't decided to revise later models, as some things can be a pain in the ass because its a late spec. My thinking with the late spec GT clocks is that: If VW revised all the engines to use one oil pressure sensor, then sure a late spec GT will have one oil pressure sensor, and will have clocks compatible with my set-up too.
Karl.
Posted: Thu Jul 29, 2004 6:30 pm
you need the engine bay wiring out of the doner mk3 to do it properly then you have all the correct plugs to swap over and solder onto your mk2 wiring loom it's alot of work but worth it to look good
