Polo GT Wiring
Posted: Mon Apr 14, 2003 10:38 am
by matt1471
im trying to put a Polo GT (1.3 with MPi) into a Mk1 golf.
the engines in but, i need to connect the Fuel pumps to the relay, and the ECU to the ignition somewhere!!
So, where abouts off the ECU loom does the fuel pump connect?? i cant find the red/yellow wire that would do this. Also, surely i need to connect the ECU loom to the ignition control?? where abouts does this happen??
in the bulkhead side of the loom (where the ECU lives), i have a plug with three wires going into it - is this the ignition control??
Lastly, on the ignition coil, there is a plug ON it and plug to the SIDE of it. Both plugs are on the loom and one of the serves the coil, the other does what??
many thanks if you can help.
matt
[email protected]
