Engine problems (engine light, ticking). Some advice needed.
Posted: Sun May 08, 2016 1:48 pm
Hi All
Recently my 2005 1.2 Polo has been bringing up the engine light on and off and there has been a ticking noise coming from the engine.
I took it to a garage a couple times and the engine light error code is coming because of an intermittent misfire which they believe is caused by a bad valve on Cylinder 3. They said it is going to cost £800 - £1100 to fix because it basically means refurbishing the cylinder head; new valves, reseating, new timing chain etc.
I am just looking to see if you think this is the right course of action. Is it worth refurbishing the whole cylinder or should I just get the one valve done, or is it worth doing them all while they have the engine in bits anyway? In your opinion as well, does it sound like a reasonable price for the work? It is half the price of the cars worth.
Thanks for your help.
