Air filter box questions
Posted: Thu Jun 16, 2016 9:48 pm
by lfcadam1993
Ok hello everyone! This may well be the stupidest question ever but I am very much a rookie when it comes to cars. I have a question that I'm guessing one of you more educated folk can answer. How many air filters are inside my air filter box unit on my 6n2 1.0??
Re: Air filter box questions
Posted: Thu Jun 16, 2016 10:39 pm
by 2015_polo
Hi there is 1 air filter in the air filter box
Sent from my SM-G920F using Tapatalk
Posted: Fri Jun 17, 2016 12:58 am
by lfcadam1993
Are there any other filters inside?
Posted: Fri Jun 17, 2016 8:45 am
by alexperkins
There's a fuel filter and an oil filter
Re: RE: Re: Air filter box questions
Posted: Fri Jun 17, 2016 8:57 am
by 2015_polo
lfcadam1993 wrote:Are there any other filters inside?
just the 1 inside the airbox but as mentioned you also have a oil filter then at the back of the car you have a fuel filter and im sure on the 6n2 the pollen filter is under the scuttle panel
Posted: Sun Jun 19, 2016 2:15 pm
by lfcadam1993
Thanks for the comments everyone, but should there be an air filter in the box thing that goes over the throttle body? Let me try and explain how mine looks, as the cover on the engine sits as you look at it as standing at the bonnet theres some kinda filter to the left, then the part that goes over the throttle body then theres a filter to the right, but my question is should there be an air filter in the middle compartment thats is sitting over the throttle body? Thanks
Posted: Sun Jun 19, 2016 2:21 pm
by 2015_polo
Yes in the box that will say 1.0 mpi on it there will be an air filter
Only filter i can think of that could be on the left is the charcol filter or if someone has fitted an aftermarket filter to the end of the air intake leading to the filter
