Pin Out BCM 7h0 937 090 B
Posted: Thu Aug 18, 2016 7:08 am
by Joe51
Hello!
Does anyone know the Pin out for the following BCM? IT's out of a beetle 5c (I think it's the same like Polo 6R etc) made 2014. Thx. Need that to install PDC
PNr.: 7H0 937 090 B
Re: Pin Out BCM 7h0 937 090 B
Posted: Thu Aug 18, 2016 8:42 am
by ciclo
Hi, Welcome.
No need to connect anything directly to the BCM, it's hardest.
What you need:
Supply
- A wire 0.5 mm from T16/1 (16-pin connector, slot 1) of new parking control unit to Fuse SC13b 5Amp
+15 (wire green/black).
- T16/8 ground (brown)
CAN line new parking control unit
- Low---- from T16/15 (orange/brown) to CAN Low in any other control unit of powertrain.
- High---- from T16/6 (orange/black) to CAN High in any other control unit of powertrain.
Some control units powertrain: Instrument cluster, Additional instruments, Headlight range control unit, Steering column electronics control unit, Power steering control unit, BCM, Engine, ABS... Choose the one you prefer to make an easy installation.
Parking aid button
The rest are the sensors and buzzers connected to the control unit J446. T12 connector/s
Posted: Fri Aug 19, 2016 3:44 am
by Joe51
Hello!
Thx a lot! I will try my Best on weekend! Its a pdc without button and only for the rear bumper! I will tell you how it works! Thx
Posted: Sat Aug 20, 2016 9:27 pm
by Joe51
Hello again! PDC Check ! There is no gateway - did it with the bcm connectors 18 and 19 !
I will upload a manual in few days!
Posted: Sun Aug 21, 2016 6:55 pm
by ciclo
Ok!, the important thing is it work properly.
PDC it's a nice improvement.
