Interior light
Posted: Tue Feb 28, 2017 9:48 am
by Vasey
Hi everyone does anyone know how you change the bulbs on the interior light,I don't fancy snapping anything trying to take it apart many thanks...
Re: Interior light
Posted: Tue Feb 28, 2017 9:49 am
by FerhaTopaLGT
It's easy you can watch on YouTube
Tapatalk kullanarak iPhone aracılığıyla gönderildi
Re: Interior light
Posted: Tue Feb 28, 2017 1:26 pm
by wrecksigge
Get a prying tool, preferably a plastic one so you wont damage the interior. Pry between the headliner and the trim itself. You will have to use some force, it is going to feel like you are going to brake something. But dont worry, they are metallclips holding the trim in place so they can handle it.
Or you can start by taking the back end off. The plastic trim that looks like its some kind of sunglass compartment but it really isnt. That piece is very easy to remove by hand. Then you can look inside and see how it all stays together. But its very straight forward. Just use some force
Re: Interior light
Posted: Fri Mar 03, 2017 10:59 am
by Asamoli
Use a suction cup, that's how I did mine stick it to the clear plastic cover and pull with abit of force and the cover will come off with the clips intact [emoji3]
Sent from my XT1572 using Tapatalk
Re: Interior light
Posted: Fri Mar 03, 2017 11:16 am
by Vasey
Asamoli wrote:Use a suction cup, that's how I did mine stick it to the clear plastic cover and pull with abit of force and the cover will come off with the clips intact [emoji3]
Thanks guys ended up taken the whole unit out then changing them cheers
