UK-POLOS.NET - THE VW Polo Forum • Parts location
Parts location
Posted: Sun May 14, 2017 2:56 pm
by Jeffliddell
Hi all just bought a 3dr 6n1 polo 99 plate. Just replaced the engine as it dropped a valve and holed a piston, now the clutch release lever where the cable connects has broke the weld. Tried welding it but it must be a cast shaft as it broke straight away. Question is can i buy a new release lever and shaft and where from. I have trawled the web to no avail. The haynes manual calls it the release lever. Any ideas anyone. Its a simple fix if i can get the part. How much if anyone has done it. Appologies if it is already in here somewhere lots of info to look at. Cheers all jeff
Re: Parts location
Posted: Sun May 14, 2017 6:56 pm
by alexperkins
Welcome
Yes it can be replaced, but in pretty sure it's a gearbox off job
I'll get you the part number tomorrow
What engine is it
Re: Parts location
Posted: Tue May 16, 2017 4:25 pm
by alexperkins
085141702B is the part number. List price is £80.95
Re: Parts location
Posted: Tue May 16, 2017 5:17 pm
by Jeffliddell
Thanks for the reply. Went to my loal vw dealer and yes the part is available on back order at the price you quoted. I removed the box and the removed the arm. Such a simple job to get the arm out. I ground the weld off cut a nice groove in the top and welded it back up. I stress tested it to be sure and put the box back in. All done in a day and working great. Thanks for taking the time to reply. The engine is 1.4 8 valve. Runs real sweet for its age.
Re: Parts location
Posted: Tue May 16, 2017 5:18 pm
by alexperkins
Was going to say, if you cut a good groove, youll get a decent strong weld 8)
These engines last forever if looked after!
