Page 1 of 2
1.0 MPI new oil leak
Posted: Sun Jun 04, 2017 6:28 pm
by piglet14
Quite wet all round sump but not making puddles yet.
Is there a favourite spot on these?
Re: 1.o MPI new oil leak
Posted: Mon Jun 05, 2017 2:42 pm
by alexperkins
Its unlikely to be the sump. The gasket is a liquid gasket and doesnt tend to degrade over time. Its more likely to be the breather on the back of the block, or a leak from above.
Re: 1.0 MPI new oil leak
Posted: Mon Jun 05, 2017 6:12 pm
by piglet14
It's up the front of the pan as well, would a leaking breather get oil that far round?
I'll have to clean it up and take the belt covers off.
Posted: Mon Jun 05, 2017 6:13 pm
by alexperkins
It can run around quite easily. The other possibility is a few loose bolts and it's coming down the thread
Posted: Mon Jun 05, 2017 6:58 pm
by piglet14
Where is the breather Alex? I'll check it out.
Posted: Mon Jun 05, 2017 7:50 pm
by alexperkins
Back of the block. Follow the crankcase breather hose down from the airbox on the left handside.
Posted: Fri Jun 09, 2017 6:04 pm
by piglet14
Do you mean the black plastic casing that's screwed to the back of the block next to the starter? Quite manky round there.
The belt covers all look nice and dry so probably not seals.
Posted: Fri Jun 09, 2017 6:24 pm
by alexperkins
Yeah that’s right
Posted: Fri Jun 09, 2017 7:00 pm
by piglet14
So what leaks then, O-ring or gasket?
Posted: Fri Jun 09, 2017 7:20 pm
by alexperkins
Sometimes the breather cracks, the hose splits, the gasket perishes
Posted: Fri Jun 09, 2017 10:26 pm
by piglet14
Aww crap, You mean I've got to pull it all out & investigate.
Posted: Fri Jun 09, 2017 10:48 pm
by alexperkins
You might be able to see it from underneath with a torch and mirror
To access it it’s normally a case of take the inlet manifold off for proper access
Posted: Sat Jun 10, 2017 8:31 am
by piglet14
Access looks OKish from underneath but I can't tell what's going on above it.
Is there a physical connection to the manifold?
Posted: Sat Jun 10, 2017 9:48 am
by alexperkins
No it goes into the block. The manifold just gets in the way
Posted: Sat Jun 10, 2017 11:51 am
by piglet14
Bit like the D/S from underneath then.
I'll have a go when I've finished drilling door frames.
