Arosa 1 piece exhaust
Posted: Tue Aug 29, 2017 6:27 pm
by piglet14
Back box has gone.
All I can find online is centre & rear sections
Mine is a VW stamped 1 piece.
Is this a case of cut & clamp the new rear on?
Re: Arosa 1 piece exhaust
Posted: Wed Aug 30, 2017 10:39 am
by alexperkins
Correct. They came one piece from the factory
Replacement will be cut and clamp.
Posted: Wed Aug 30, 2017 2:34 pm
by piglet14
Thanks Alex,
Looking forward to this one, not.
Posted: Wed Aug 30, 2017 3:48 pm
by alexperkins
It’s fairly straightforward. Remove the entire one piece from the car, measure and cut then sleeve the new one on once refitted
Posted: Wed Aug 30, 2017 10:23 pm
by piglet14
All done, cut the pipe on the car rather than try and disturb the nasty looking joint behind the cat.
Bit fiddly but done worse.
Joint leaks a bit, don't know what's considered acceptable.
Used to use Gun Gum in the bad old days.
Posted: Wed Aug 30, 2017 11:45 pm
by alexperkins
You are best to seal it up with gun gum. Needs to be fairly tight from a leakage perspective
