One tail light dimmer than other
Posted: Sun Oct 08, 2017 9:50 am
by hadi125
Hello folks
On my polo 1.2 match the right tail light is considerably dimmer/weaker than the left one. To the point that in the day time you can’t even see it. Any reasons for cause and/or solutions?
Re: One tail light dimmer than other
Posted: Sun Oct 08, 2017 9:54 am
by Dink
could be a bad earth connection.
check the other lights see if they are the same.
Posted: Sun Oct 08, 2017 6:52 pm
by RUM4MO
I'd suggest that you start with some basic checks, so, get both rear clusters out and check which bulbs are in each - and check that the tail lights do not use two bulbs but one has failed.
Posted: Sun Oct 08, 2017 7:02 pm
by iichel
Bad earth connection would dim all the light one cluster, not just a singular bulb.
A dying light could go a bit dim.
Posted: Thu Nov 23, 2017 2:05 pm
by hadi125
Got the problem solved. The tail light had a faulty manufactured bulb. Front sidelights had some loose wiring
