Aftermarket Stereo
Posted: Mon Feb 19, 2018 7:12 pm
by MJGRiFFiN
Hi all,
So I've recently picked up a 9N3 Polo and decided to fit an aftermarket stereo.
I've installed it using a quadlock ISO but had the same issue that others have faced and that's the stereo staying on after key is pulled.
I done a little search and someone had success swapping the red wire with the blue wire on on the adapter, so red is connected to blue and blue is connected to red. To my surprise, this worked.
But i am left worrying if that's a good solution or am I going to wake up with a flat battery?
Thanks.
Re: Aftermarket Stereo
Posted: Tue Feb 20, 2018 9:36 am
by alexperkins
Which blue wire have you used? Normally, you have to tag the ignition live onto the back of the cigarette lighter or something else fed from the ignition.
Posted: Tue Feb 20, 2018 12:42 pm
by MJGRiFFiN
alexperkins wrote: Tue Feb 20, 2018 9:36 am
Pretty sure it's the remote wire.
Went to car this morning and started as normal, no flat battery.
Posted: Tue Feb 20, 2018 12:44 pm
by alexperkins
Presume this is a blue wire on the car side of the loom rather than the radio?
Posted: Tue Feb 20, 2018 12:47 pm
by MJGRiFFiN
alexperkins wrote: Tue Feb 20, 2018 12:44 pm
Thats right.
If needed, I can upload a picture later tonight
Posted: Tue Feb 20, 2018 12:58 pm
by alexperkins
I think it would be beneficial to pop a photo up - also showing what wire on the quadlock the blue wire goes through too aswell and ill check what it does
Posted: Tue Feb 20, 2018 1:04 pm
by MJGRiFFiN
alexperkins wrote: Tue Feb 20, 2018 12:58 pm
Okay will do.
Basically, the blue wire from the car side now connects to the red wire. And red wire car side now connects to blue/white wire.
