NextBase Duo dashcam
Posted: Sun Mar 11, 2018 3:46 pm
by Mike Austin
Has anyone fitted one of these? I got one before buying my Blue GT. It seems too big to fit behind the rear view mirror while still allowing clearance to detach from its mount.
Re: NextBase Duo dashcam
Posted: Sun Mar 11, 2018 6:35 pm
by RUM4MO
Hum, that is what I have thought! What size is the VW branded one? Ever considered just buying a kit with separate front and rear cameras or even mounting the front camera sensor within the mirror base?
Posted: Sun Mar 11, 2018 7:00 pm
by Mike Austin
RUM4MO wrote: Sun Mar 11, 2018 6:35 pm
I may have to consider that now. The main problem is the mounting bracket size - just too big, even with the smaller adhesive pad. If the camera could fit closer to the windscreen, it could work. If would be difficult to fit the camera to the back of the mirror, and all the controls would be inaccessible.
Posted: Mon Mar 12, 2018 9:44 pm
by Mike Austin
My brother-in-law has the same dashcam mounted directly under the mirror. He has a bigger windscreen (Skoda Yeti) but I would have thought there are regulations about how much windscreen space can be obscured by such devices. I am not sure I would like it there anyway, legal or not.
Posted: Thu Mar 22, 2018 1:14 pm
by Mike Austin
I have now fitted the dashcam. It is large, but not as bad as I thought.
Because the camera can be twisted and the lens rotated to compensate, it can be partly hidden by the rear view mirror.:
The view from the passenger's side shows the twist:
The wiring into the fusebox was straightforward - piggy back on fuse 27, the rear window wiper. The usb cable and adapter box were tidied up and put into the space just under the steering wheel:
The two lenses on this dashcam can be rotated about a vertical axis independently. Tilting up/down affects both cameras and is a compromise between getting the front view and rear view centred.
