Folding mirrors wont unfold after about a minute.
Posted: Tue May 15, 2018 11:16 am
by martijnoss
Helo guys
I place folding mirrors in my polo 6r 1.2 bleumotion 4doors with the guide from ciclo.
The motors i used is with softwarerversion s9210 the coding i used is
0200A3(13 pin motor)
1000AB(7 pin motor)
When i fold the mirrors and put the key in the contact they unfold but only till about 1 minute.
After i stay away for more then about a minute the mirrors wont unfold with the key in contact, the only solution then is to do it with my switch.
Do i need an other code or something?or do something else in vcds?
thanks in advanche
Re: Folding mirrors wont unfold after about a minute.
Posted: Tue May 15, 2018 9:10 pm
by ciclo
Autoscan, please.
Posted: Tue May 15, 2018 10:39 pm
by martijnoss
hi
Sorry you're right.
so i have it here.i hope it can be fixed because this retrofitting is great upgrade in my opinion.
Tuesday,15,May,2018,14:23:33:04550
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WVWZZZ6RZCY018898   License Plate: LOG FOR UK POLOS
Mileage: 209980km-130475mi   Repair Order:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6RZCY018898   Mileage: 209980km-130475miles
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9979
   Revision: 12005001    Serial number:
   Coding: 00114014032401080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021B 001042
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 27B82C1356E28C2AA4B4E6-8072
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3416E00BA842D24EB82D900521300
   Shop #: WSC 00788 648 00255
   VCID: 07F84C93B622A02A847406-8052
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 389AFF6F8B5C1BD23D0E3D-806C
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0351
   Revision: BU050001    Serial number: 0456 157110196
   Coding: 3AB02BBF08F32400B3300FF06CEB0ED0FF8067FF7E862481200000000000
   Shop #: WSC 124697 483 00190
   VCID: 416C928BD8865A1A8AB098-8014
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 030611 05  54  0403
   Coding: 02302D
   Subsystem 2 - Part No SW: 6R0 959 801 CE    HW: 6R0 959 801 CE  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 9610
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 CJ    HW: 6R0 959 802 CJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 9610
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 48BC32
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX00NYMLN
   Coding: 00314D
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4A7EB5A7E5B091425BDA67-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405R0ILP0CPGD
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB40510ILP068LD
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515RRB404P0K4DOE8S8
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525RRB40510JNPM88S8
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140801
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 3A9EE567B55001C2CB7AD7-806E
   Coding: 140801
Address 19: CAN Gateway (J533)       Labels: 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0034
   Revision:   H38       Serial number: 310511F1000209
   Coding: 2500C2
   VCID: 3482CB5F9734FFB2113669-8060
   Component: IMMO          H03 0505
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6A3E1527857071427B1AC7-803E
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660151535
   Coding: 020000
   VCID: 29BC2A2B40F6B25AB2A090-807C
Address 37: Navigation (J794)       Labels: 3C0-035-270.clb
   Part No SW: 3C0 035 270 B    HW: 3C0 035 270
   Component: RNS310        H19 0357
   Revision: 11000000    Serial number: VWZ1Z2L7243310
   Coding: 040004010400000000000000
   ASAM Dataset: VW_RNS310 A02007
   ROD: EV_VWRNS310UDS.rod
   VCID: 19DC1AEB10962ADA22C040-804C
8 Faults Found:
1048593 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
1048594 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
1048595 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
1048596 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
1048597 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
1048598 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
1048599 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
1048600 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 209980 km
                    Date: 2018.05.15
                    Time: 23:15:01
   Part No: 6R0 423 156 B
   Coding: 11260
   Shop #: WSC 00788
   VCID: 2F88C4337E12486A6CE45E-807A
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0034
   Coding: 030B1A5A
   VCID: 74020B5FD7B4BFB2D1B6A9-8020
   Subsystem 1 - Part No SW: 6R0 915 181 D    HW: 6R0 915 181
   Component: J367-BDM  H07 0180
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 G    HW: 7P6 035 730 G
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660128307
   Coding: 0800000000000210
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA.rod
   VCID: 3686F1578148E5A22F2203-8062
End-------------------------(Elapsed Time: 02:52)--------------------------
Posted: Wed May 16, 2018 7:24 pm
by ciclo
It's weird, it should work correctly.
Hmm... enter this coding in both rear WRMs.
18BC32
I don't think it's related, but it's about trying something new. I have this coding in my rear WRMs from factory. (they are the same as yours.)
BCM, Bluemotion, I don't know what to think.
Tell us if you appreciate any change.
Posted: Thu May 17, 2018 4:22 pm
by martijnoss
Hi ciclo
Thanks for you're help but it make no difference.
I have googled for 1 evening but I can't find it.
I thought of was a minuten but after 20 seconds or so of won't work anymore.
Posted: Thu May 17, 2018 6:19 pm
by ciclo
Test these codings for front WRMs
Coding: 0400A3
Coding: 1400A3
Posted: Thu May 17, 2018 8:57 pm
by martijnoss
First of al thanks for the reply.
I have tried the last code but it make unfortunately no difference, I have tried them with my original coding in the back and the one you give.
I was thinking the mirrors are Chinese, does make that the problem.
It is working(between the short tine) so I don't think so.
ps
i am looking already for originals for the case that is the problem, i wil solve it because it must work.
does the 6C mirrors fit like number
6C1857507C9B9
Posted: Fri May 18, 2018 6:58 am
by ciclo
martijnoss wrote: Thu May 17, 2018 8:57 pm I have tried them with my original coding in the back and the one you give.
It's the way to do it, well done.
martijnoss wrote: Thu May 17, 2018 8:57 pm I was thinking the mirrors are Chinese, does make that the problem.
If they're VW OEM there is no problem.
If they work, they're fine.
martijnoss wrote: Thu May 17, 2018 8:57 pm does the 6C mirrors fit like number
6C1857507C9B9
Yes.
Posted: Sun May 20, 2018 6:56 pm
by martijnoss
Hello again.
Now i got a little bit of a headache from the mirrors.
Yesterday i was at the scrapyard and take 2 original mirrors 6C1857507C9B9, 6C1857508C9B9.
But still dont work.
I tried every coding you give me, also in combination.
I dont want to give up but i dont know where to search/look now.
The wiring was the same as the chinese.The pictures are from the oem mirrors.
Posted: Sun May 20, 2018 8:42 pm
by ciclo
The problem is not in the wiring because the mirrors worked. Not in the correct way, according your explanation, but they did it.
I don't have other solutions.
Posted: Sun May 20, 2018 9:21 pm
by martijnoss
oke, thanks for youre help anyway.
I dont give up, is it possible that the motors with software 9610 are fault beceuse then i look for the same motors u have.
S8612 u have right?
Is it safe to reset the bcm to factory defaults?
Posted: Mon May 21, 2018 5:52 pm
by ciclo
My WRMs
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000A3
martijnoss wrote: Sun May 20, 2018 9:21 pm Is it safe to reset the bcm to factory defaults?
What do you mean by "Reset"? Do you have this option in your VCDS?
Who did your current BCM coding? :lol:
Posted: Mon May 21, 2018 8:22 pm
by martijnoss
Hi
I thought it was factory default, but proberly there is factory mode.
now i have bought an genuine cable and wednesday the delivery guy is gonne bring him.
My bcm is a 88 they should do the trick right.
Looking for the wrm with you're or iichell S numbers.
Edit:Today i bought 2 wrm 6R0959801BD 6R0959802BF 8612, tommorow i install them.
Edit2: yeah ik have install the other wrm with the S8612 and now it worked flawlessly with coding 0200A3 and 1000AB, with the china cable but tommorrow i have a real one because i needed that anyway.
I would thanks everyone and special thanks to Fernando.
Up to a new project.
I think a steering wheel.
Posted: Wed May 23, 2018 8:29 pm
by ciclo
Thanks to you for sharing your experience with us. 8)
