Difference in heated seat modules
Posted: Mon Sep 24, 2018 11:22 pm
by golffather
Does anyone know the difference between 6r0959772A and 6r0959772D ?
Both are valid part number, A being fitted to 6R and D to 6C
Retrofitting Audi heated seats to 6R and just trying to figure out the difference and which is the best module to use.
Audi use D version throughout the A1.
Re: Difference in heated seat modules
Posted: Tue Sep 25, 2018 9:38 am
by iichel
I'm using a 6R0959772C and 6R0959772D in my 6R (resp front and rear). I have no issues so far with any of them.
Posted: Tue Sep 25, 2018 10:19 pm
by golffather
thanks!
How did you wire in rear heated seats?!
Posted: Tue Sep 25, 2018 10:29 pm
by iichel
same as the fronts really. :mrgreen: just different lengths for the wiring loom, otherwise identical.
Posted: Wed Sep 26, 2018 1:45 pm
by golffather
Great!
Any tips you can provide for wiring the Audi seats, using Kufatec loom in a 6R?
Posted: Wed Sep 26, 2018 5:56 pm
by iichel
I don't know, sorry.
Posted: Fri Sep 28, 2018 1:37 am
by golffather
Do you know what output is provided by bcm to the heated seat module? Is it +12v to activate it?
Just wondering if i can still use the heated seats without connecting and activating the bcm
Posted: Fri Nov 30, 2018 9:14 pm
by golffather
@iichel
Did you connect the rear seats to the BCM as well?
Or do they work without any BCM connection?
Posted: Sat Dec 01, 2018 8:05 am
by iichel
They will work without BCM connection as well, however I did connect them. I think the wire prevents the heater from going on when the battery cannot sustain it yet
Posted: Mon Dec 03, 2018 10:32 pm
by massimo23
hi lichel i see ur a busy man retrofitting your car. i was wondering if it is possible to install heated front seats for my polo 6c 2016? i dont have climatronic. thanks
Posted: Tue Dec 04, 2018 6:41 am
by iichel
Yes, certainly that's possible!
