Hi everyone
Does anyone know how to re-code the gear change indicator arrow on the dashboard, so that is shows at certain RPM?
Currently, it suggests an up-shift at under 1800-1900RPM. If following the suggestion, I can feel that I am murdering my engine slowly.
So, how can I re-code the indicator, so that the arrow up shows on the MFD at 2400-2500RPM?
Car: Polo 1.6 tdi BMT 2011
Thanks.
Re-coding the gear change indicator on dashboard to certain RPM?
- Drives: VW Polo 6R_C 1.6 TDI BlueMotion CAYB
Re: Re-coding the gear change indicator on dashboard to certain RPM?
I don't think it's possible
I wonder if it is purely engine RPM that triggers these gear change warnings - I would think that it will be engine load and/or instantaneous fuel consumption as well as RPM or instead of engine RPM.
I think it is also set up for people that have a very slow working brain so that by the time you accept that you are being advised to change gear, it will be the correct time? (that was just a joke!)
Just ignore it and drive normally. IMO when to change gear shouldn’t be dictated by a gear change indicator.Blacksmoke wrote: ↑Sat Oct 13, 2018 8:15 am Hi everyone
- Drives: Polo R WRC 2014
Yeah, it is definitely not dependent only on rpm but also on engine load and pedal inputs.RUM4MO wrote: ↑Sat Oct 13, 2018 9:38 am I wonder if it is purely engine RPM that triggers these gear change warnings - I would think that it will be engine load and/or instantaneous fuel consumption as well as RPM or instead of engine RPM.
