How to turn off synchronised mirrors?
Posted: Fri Aug 20, 2004 1:46 pm
by pukka
Not sure how I turned this on in the first place. But now when I have the electric mirror joystick in the 'R' position and move the joystick, both wing mirrors will move in sync.
Looked in the manual, but don't think it's very clear. How do I turn this feature off? ie. so 'R' only moves the right wing mirror, not both.
Thanks in advance. :)
Posted: Fri Aug 20, 2004 1:52 pm
by des_pd_ tdi
You can't turn this function off.
Just set your right mirror with R (this does both) then adjust your L mirror.
How often do you really adjust your mirrors once your satisifed?
This function is especially useful if you need to reverse into your garage, both mirrors adjusted to the angle down position in one hit, then both adjusted back using the R position.
Des
