Crashed my polo HELP!
Posted: Fri Jan 04, 2019 7:09 pm
by LawrenceDGraham
I've just crashed my polo gti 6c tonight and can't find for the love of god a bumper for it so I've seen this WRC aftermarket one https://ebay.us/hEzmGO
Will it fit with out any bother just it looks a bit wide on the wings or should it just be bolt on. And will them little fog lights put a light on the dash or should be all good.
And if anyone knows of a decent bumper going for a decent price hit me up.
Re: Crashed my polo HELP!
Posted: Fri Jan 04, 2019 7:43 pm
by iichel
if you want a decent bumper, stay away from aftermarket stuff
Posted: Fri Jan 04, 2019 8:00 pm
by SRGTD
Here’s one, which looks as if it just has some minor scuff marks on the nearside. These could be sorted when it’s sprayed (black?) to match your car. If your car’s got parking sensors, holes will need to be cut to fit the sensors in.
https://www.ebay.co.uk/itm/273609734345 ... noapp=true
As iichel has said, avoid the aftermarket ones which may be poor quality and may not be a good fit - it could leave you with uneven panel gaps where the bumper meets the front wings. Even if it bolts straight on, looking at the picture, it doesn’t accommodate the GTI’s headlamp washers. Also, in the picture of the blue Polo in the link you posted there’s no depression in the upper middle section of that bumper for the VW grille emblem to fit into, although the pictures of the grey primered version does have the depression in in the middle to accommodate the VW emblem. You may get a ‘bulb out’ error message, as your car has static cornering lights and that bumper doesn’t accommodate them without modifying it.
Stick with the OEM bumper as it’ll be a straight bolt on replacement.
Posted: Sat Jan 05, 2019 6:52 pm
by cheba
I'd also recommend a original bumper, try to find one used.
The aftermarket bumper in the link in the first post is not a WRC bumper, the WRC bumper looks completely different. The one in the link is a Polo bumper that is designed to look like the mk6 Golf R/Scirocco R bumper. Not only is is an aftermarket bumper, but there is no OEM bumper that looks like that that they could have copied, so the fitment is likely not good. Plus it doesn't have the openings for headlight washers.
On top of that, the beam behind the bumper has different part numbers for Polo 6R and 6C meaning there might be some differences in geometry, so I strongly recommend going for an original 6C bumper.
Posted: Sun Jan 06, 2019 1:25 am
by CNK
Polo 6R bumpers fit into 6C, but don't buy aftermarket, only OEM! :wink:
