I have the chance of buying sports seats from a 2007 3 door car. My car is a 5 door. Does anyone know if they will fit.
Also, how good are the sports seats
Puting 3 door seats into a 5 door car
- Drives: 9n3
Re: Puting 3 door seats into a 5 door car
Hello mate did u get any luck at all, I’ve got the same idea wondered if it worked or not ?
- Maarten
- Drives: AW R-line Facelift MY2022 Vibrant Violet
They will fit.
Just the 3 door seats have the pull down handel.
Rear seat no problem. Just make sure the middle seatbelt is still attached
Thank you Maartin. I have not sourced or installed any yet but will now start searching.
- Maarten
Be sure to use the right tool to loosen the screws that hold the seats to the body.
They look like Torx (6 teeth) but it is multi tooth (12 teeth)
