Anti-theft system info
Posted: Fri May 17, 2019 9:39 pm
by Luigid
hello guys, I installed the original volumetric alarm on my 2010 6r polo (sensors + siren + button), the alarm works, I wanted to know the various settings below:
siren tone type : Does the sound vary if continuous or discontinuous?
siren alarm type:what changes between the rest of the world / england-ireland?
http://wiki.ross-tech.com/wiki/index.php/01044
do I have to select an alarm in the gateway? (now I'm seeing this possibility I hadn't thought of it) or should I do something else? the best coding to make the siren sound as high as it would be? thank you
Re: Anti-theft system info
Posted: Sat May 18, 2019 11:21 am
by iichel
Ireland/row has something to do with the duration of the alarm.
Can you show a full scan please?
Posted: Sat May 18, 2019 1:46 pm
by RUM4MO
Yes, I was going to reply with that comment, I think that Ireland/UK is that the sounder only runs for something like a 1 minute or 2, then stops running, checks status and if still armed sounds again for 1 or 2 minutes and so on.
Posted: Sat May 18, 2019 8:59 pm
by Luigid
iichel wrote: Sat May 18, 2019 11:21 am
Saturday,18,May,2019,20:59:33:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZAYXXXXXX License Plate:
Mileage: 74150km-46074mi Repair Order:
Chassis Type: 6R-VW25 (6N0) ->[color=#FF0000]6n0?[/color]
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: WVWZZZ6RZAYXXXXXX Mileage: 74150km-46074miles
Address 01: Engine (J623-CAYA) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 E HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 8830
Revision: --H13--- Serial number: 00000000000000
Coding: 00114014002400080000
Shop #: WSC 00914 264 96370
ASAM Dataset: EV_ECM16TDI02103L906023E 003010
ROD: EV_ECM16TDI02103L906023AH_003.rod
Readiness: 1000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 210228E3416D00B4842914EB82D600421100
Shop #: WSC 00011 888 77253
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0650
Revision: 00 10 24
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 11163 km
Time Indication: 0
Date: 2016.06.02
Time: 23:02:00
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number:
Coding: 3CB02BBF08E12400903000007C2D0CD00088410F60860000200000000000
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0902
Serial number:
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number:
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000 [color=#FF0000]coding all 0?[/color]
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number:
Coding: 08BC32
Subsystem 7 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number:
Coding: 08BC32
2 Faults Found:
01758 - Bulbs for Brake Lamps [color=#FF0000]I can't turn them off, I put the LED :S[/color]
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 11
Reset counter: 146
Mileage: 74089 km
Time Indication: 0
Date: 2019.05.17
Time: 13:05:23
01044 - Control Module Incorrectly Coded [color=#FF0000]there is[/color]
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 74089 km
Time Indication: 0
Date: 2019.05.17
Time: 13:05:24
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag005 H09 VW10Airbag005 H09 00180018
Revision: -------- Serial number:
Coding: 003035
Shop #: WSC 124697 483 00190
ROD: N/A
Serial number:
Serial number:
Serial number:
Serial number:
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6JA 920 840 E HW: 6JA 920 840 E
Component: KOMBI H01 0711
Serial number:
Coding: 540800
Shop #: WSC 73430 031 00125
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002200
Component: IMMO H01 0711
Coding: 000002
Shop #: WSC 00000 000 00000
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11210
Shop #: WSC 00000
End-------------------------(Elapsed Time: 03:03)--------------------------
for hvac sometimes that error comes up other times this:
where is this sensor?
it seems that the error is because the siren and the two sensors have all the coding at 0 .... but how are they coded and what should their coding be
