VW Polo 3 (6n2) - Fault: 17559
Posted: Fri Jun 21, 2019 6:36 pm
by bpjl
Hey.
Some time ago (rather longer than shorter) in my VW Polo 3 (6n2, 1.4, 75KM, 2000) Check Engine was lit. I used the simplest interface and (without thinking) removed the error. I did not wait too long for Check Engine to shine again. Then I decided to get interested more. Here is the error:
1 Fault Found:
17559 -  Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Lean
        P1151 - 35-10 -   - - Intermittent
I know that the reasons may be the whole list, but most of the internet indicates a lambda probe. Can anyone explain to me how to diagnose such a probe (and maybe even probes) using VCDS connected to my Polo?
Re: VW Polo 3 (6n2) - Fault: 17559
Posted: Sat Jun 22, 2019 8:20 am
by 937carrera
You can test the performance by using VCDS and going through a test cycle which I remembered was activated by pressing the brake pedal
Take a look here and then you can do some more reading with pre knowledge :)
https://www.briskoda.net/forums/topic/3 ... ing-tests/
https://www.ross-tech.com/vag-com/m_blocks/030-049.html
After I did the tests I think I ended up replacing the lambda sensor (proper Bosch one) and all was good
Posted: Mon Nov 11, 2019 8:40 pm
by dipstr
Check the lambda probe multiplug. Very common for the wiring to break. It is the one connected to exhaust manifold. The multi plug connector is in a housing by the gearbox
Sent from my SM-G950F using Tapatalk
