No fuel Polo 1.2TDI
Posted: Sat Jul 20, 2019 9:22 am
Hi there, I need help with an issue. I have a 2012 1.2tdi polo. The problem is that I get fuel from the tank to the fuel pump at the engine and fuel passes through the fuel filter to the high pressure fuel pump but there isn't any fuel from the hpfp to the fuel rail. It goes back from the hpfp to the return. The car has a go swing but it won't start because there isn't any fuel from the hpfp to the fuel rail and from the fuel rail to the injectors. I have replaced the hpfp twice now with both secong hand units being taken off running polos. I have used the vcds but no codes, I tried bleeding the system with vcds but no luck. Please please help. Thanks
