Strange OEM radio problem - it lights up when the car lights and ignition are off.
Posted: Mon Nov 11, 2019 3:33 pm
I have a 2002 registered Polo Classic. I've had some issues with the wiring loom and corrosion in the connectors. Took me a while to sort that, was corrosion on the connectors for the TPS (Throttle Position Sensor) and I was getting a TPS error on the diagnostic software.
That was over a month ago and the new issue I think must also be due to a wiring/connector issue somewhere. What happens and it might have been happening for some time but only noticed it with the darker winter nights is that when the ignition is turned off the radio lights come on. The radio stays off. If I switch the radio on the lights then go off but when I switch the radio back on half the time the radio waits about 5 seconds and then slowly the lights come back on (as if dimmer switch is slowly turned on).
I'm not expecting an immediate diagnosis although that would be great but suggestions as to where to look and what to check would be very helpful.
