[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 RCD 200 Stock Radio - UK-POLOS.NET - THE VW Polo Forum
I'm trying to install an Edge 12" Sub on the stock radio
I can either use High-level input or get a low-level adaptor but not sure which to go with
And how would I go about getting a remote turn on, could I use the cigarette lighter as that is controlled with the ignition
If it's got a high level input then use that (basically has the hi-lo converter built in). You could just run an extra set of wires from the rear speakers.
As for remote turn on you could just use an add a fuse adaptor in the fuse box off an ignition switched supply and stick the lowest rated fuse you can find in it.
So since I don't have rear speakers I have four spare connections in the wiring harness should I use them or just splice the front speaker wires in the harness or does it not really matter?
