Polo 6r windows not working!
Skllzhd
Drives: Polo 6r
Post by Skllzhd »
Hi guys.. i have a 2012 polo 6r and the master switch from the drivers side is not working at all for any of the windows, the only way i can open the drivers side window is by holding the unlock button on the keyfob, the others work fine if pressed on their respective doors..
I replaced the switch with a 2nd hand one from ebay but still the same.. could it be that they sold me a broken one or is it something else causing the problem?
This is what i get from vcds
1 Fault Found:
03589 Switch for Driver Side Window Regulator
014 Defective
Freeze Frame
Fault Status 01101110
Fault Priority 2
Fault Frequery: 1
Reset counter 41
Mileage 64962 km
Time Indication 0
Date 2015 03 08
Time 08 29 35
Any help much appreciated
Re: Polo 6r windows not working!
It could be a problem with either the wiring to the switch or the door motor, where the buttons connect to.
Skllzhd
Drives: Polo 6r
Post by Skllzhd »
I had a look at the wiring and everything looks fine.. how could i test the wires? Using a Multimeter and see if there is power getting to the switch?
yes, load test all wires
