Beats sound system
Posted: Sat Oct 31, 2020 11:03 pm
by J+silva
Hi Is there anyone with the system beats sound in the car? Could you tell me the codes that are there with obd, I retrofit my car radio but I have no sound because I have beats system and I do not now how to code it. Thanks.
Re: Beats sound system
Posted: Sun Nov 01, 2020 12:11 am
by massimo23
I have a polo beats 2017 model. This is the scan:
Friday,22,March,2019,15:01:15:29555
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 47 5F
47-Sound System -- Status: OK 0000
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2496
Revision: 33H20000
Coding: 01110032022401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
ROD: EV_ECM10MPI01104C906057AB.rod
VCID: 6596445665E6F11F0DB-8030
Readiness: 0000 0000
Part No SW: 6C0 907 379 N HW: 6R0 907 379 BA
Component: ESP9.0i H04 0005
Serial number: 08500081160603
Coding: 23DD2485492533C6091A106D0059C42492CC90080005CBF98F00
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 3A2CC72ABCD8AEE7909-806E
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 E HW: 6C0 820 045 E
Component: AC Manuell H03 0203
Serial number: 1605311B-0871
Coding: 200100001100100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 211E1046314EDD3FB13-8074
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0093
Serial number: 006238046367
Coding: 0300084042530A7B4F844000402703C800005B0253010000000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 313EE00661AE6DBF213-8064
Rain Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S2Y16M06D13H01M25S49
Coding: 0038DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 DM HW: 6R0 959 802 DM Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU002051661237247
Coding: 1400A1
Front Passengers Door Control Module:
Subsystem 3 - Part No SW: 6R0 959 801 DK HW: 6R0 959 801 DK Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU003051661240066
Coding: 0400A1
Drivers Door Rear Control Module:
Subsystem 4 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU010061661626049
Coding: 1400A0
Passengers Rear Door Control Module:
Subsystem 5 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU011061661634756
Coding: 0400A0
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331616502046
Coding: 0031151001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 43D2BACECB12EF2FC3F-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 08061603214364
Coding: 00000000FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00Q 002 0380
Revision: -------- Serial number: 003TH007XNP8
Coding: 88C0C000000000005C0000CA008800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 410 823 005 16
Component: SideSensor_Df 151 0800
Serial number: 3575H009D2101ED120FM
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 410 823 005 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00AB2101ED2D11L
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 152 605 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A51E344453395
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 152 505 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C12060D75E37B
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 740 E HW: 6C0 920 740 E
Component: KOMBI 202 2310
Coding: 272D09002180000801883E011800000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 241019522E5CC817DA5-8070
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0093
Revision: -------- Serial number: 006238046367
Coding: 030100046F0A640071000000000000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2614035A58603A07C41-8072
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Serial number: 1531611045001220AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 53160F41405881211334
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AG HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3232
Serial number: CG661488
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6E843B7AB01032477C1-803A
Address 47: Sound System (J525) Labels:* None
Part No SW: 5Q6 035 456 HW: 5Q6 035 456
Component: KonzernAmp 8K H01 2426
Revision: -------- Serial number: A1117A00000637
Coding: 0262000000AAAA00000000000000
ASAM Dataset: EV_AMPCAN8C1PASE 001015
ROD: EV_AMPCAN8C1PASE_VW26.rod
VCID: 73B22A0EDB321FAF93F-8026
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 824 B HW: 3Q0 035 824 B
Component: MU-S--ER H30 0367
Serial number: VWZAZ2S0301324
Coding: 02620000AA00000051110003000808001F0210D60120010003
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2C00F172468C0057125-8078
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 6C0 919 603 B HW: 6C0 919 603 B
Component: ABTm_Std2 H53 1031
Serial number: VWZ8Z9SKW00Y3K
End----------(Elapsed Time: 00:57, VBatt start/end: 12.0V/12.0V)-----------
Friday,22,March,2019,15:05:58:29555
www.Ross-Tech.com
VIN: WVWZZZ6RZHY026648 License Plate:
Mileage: 34825km-21639mi Repair Order:
VIN: WVWZZZ6RZHY026648 Mileage: 34825km-21639miles
Revision: 33H20000
Readiness: 1110 0001
Coding: 0038DD
Coding: 1400A1
Coding: 0400A1
Coding: 1400A0
Coding: 0400A0
Coding: 0031151001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 280000
Coding: 000700
End----------(Elapsed Time: 00:54, VBatt start/end: 12.0V/12.0V)-----------
You must log in or register to reply here.
Posted: Sun Nov 01, 2020 12:20 am
by massimo23
Also these are the adaptions for 5F Infotainment Control Unit:
Control unit: 5F Information Control Unit
System description: MU-S--ER
Software number: 3Q0035824B
Software version: 0367
Hardware number: 3Q0035824B
Hardware version: H30
ODX name: EV_MUStd4CTSAT
ODX version: 001022
Backup name: information control unit
Long coding:
02620000AA00000051110003000808001F0110D60120010003
byte_0_brand:
VW
byte_1_Car_Class:
2
byte_1_Car_Generation:
6
byte_2_Car_Derivate_Supplement:
0
byte_3_Country_Navigation:
no_country
byte_15_Wireless_Charging_Availability:
not installed
byte_4_Channel_4_TT:
installed
byte_20_display_1:
connected
byte_12_Microphone_4:
not connected
byte_12_AM_FM_DAB_antenna:
Not activated
byte_24_Emergency_Call:
On
byte_22_Touch_Screen_Remote:
Off
byte_9_Band_Settings_AM_Tuner:
EU_RdW
byte_11_Sound_System:
Sound_System_external_BAP
byte_16_Bluetooth_Audio:
available
byte_12_HD_FM_Antenna_Mode:
AM_FM_ANT
byte_14_hd_radio_coding_am:
Not activated
byte_13_AF:
persistent
byte_13_DAB_Alarm_Announcement:
Not activated
byte_13_Radio_Text_Plus:
activated
byte_13_BWS:
no_BWS
byte_16_legal_rvc:
No
byte_16_Bluetooth_Visibility:
auto
byte_17_Skinning:
Skin_1
byte_18_Screenings:
16
byte_19_Log_Book:
not_displayed
byte_19_Suspension_Arm_Side:
right_hand_drive
byte_19_Kombi_Track_Station_Info:
long_info
byte_24_Voice_Control_System:
activated
byte_19_USB:
usb_ipod
byte_20_dashboard_communication:
BAP
byte_22_Dashboard_Graphic_Variant:
via CAN
byte_22_wheel_drive:
front
byte_23_Display_Turn_Out_Speed:
normal
byte_22_Keypad_Rear_Keys:
Not available
Adaptations:
Developer mode:
activated
Confirmation of installation change:
Key:
4a21
Check tone frequency:
High note frequency range:
4000 Hz
Medium note frequency range:
1000 Hz
Low note frequency range:
100 Hz
Electrical test of loudspeakers:
Mode:
automatic
Parameter_AC-Diagnostics_Channel_1_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_1_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_2_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_2_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_3_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_3_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_4_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_4_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_5_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_5_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_6_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_6_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_7_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_7_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_8_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_8_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_9_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_9_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_10_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_10_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_11_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_11_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_12_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_12_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_13_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_13_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_14_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_14_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_15_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_15_Test_Volume:
36
Parameter_AC-Diagnostics_Channel_16_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_16_Test_Volume:
36
CD eject button:
CD eject button:
Enabled
Production mode:
000000
Deactivate production mode:
Number 1 for Info call:
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Number 1 for roadside assistance:
Number 2 for roadside assistance:
Number 2 for Info call:
Base volume of speech output:
50 %
Base volume of telephone:
50 %
Microphone sensitivity:
0 dB(A)
Bluetooth:
On
Bluetooth: Sniff mode:
Off
Selection of release codes for a SWaP function:
ffffffff
Infotainment recorder:
activated
Dimming_Ambient_Illumination_Information_Control_Unit:
X1:
0
Y1:
0
X2:
50
Y2:
50
X3:
100
Y3:
100
Dimming_Ambient_Illumination_Operating_and_Display_Unit:
X1:
0
Y1:
0
X2:
50
Y2:
50
X3:
100
Y3:
100
Dimming_Illumination_for_Display_Unit:
X1:
0
Y1:
1 %
X2:
10
Y2:
1 %
X3:
100
Y3:
8 %
X4:
150
Y4:
20 %
X5:
220
Y5:
60 %
X6:
253
Y6:
100 %
p_HMI_Display:
p_HMI_Display:
13 %
p_damping_Display:
p_damping_Display:
5 ms
BAP_Debug_Mode_Release:
Release:
not_released
Startup_Screen_Sticker_HMI:
0
Vehicle_configuration:
VZAPro:
Off
online_POI:
Off
online_POI_voice:
Off
online_portal_browser_services:
Off
online_navigation:
Off
online_street_view:
Off
WIFI_Hotspot:
Off
my_audi:
Off
picture_navi:
Off
online_dictation:
Off
remote_HMI:
Off
advanced_range_display:
Off
gracenote_online_coverarts:
Off
gracenote_online_other:
Off
gracenote_local_coverarts:
Off
gracenote_local_other:
Off
UPnP:
Off
OPS_display_in_dash_board_display_unit:
Off
Joker_button_1:
Not present
Joker_button_2:
Not present
LTE_modul:
activated
Support_second_phone:
On
Support_of_threeway_calling:
Off
Dtmf_without_active_call:
On
Support_for_response_and_hold:
Off
Sim_card_mode_switch:
Not present
Phone_module_operation_mode:
Data & language service active
PSD_Protocol_Version:
PSD_1.5
RVC_video_input:
FBAS
Station_Logo_DB_Mode:
1
TPEG_availability:
Off
VZO:
Off
LGI:
Off
ProbeCar_vzo:
Off
online_media:
Off
ProbeCar_lgi:
Off
Baidu_Car_Life:
Off
Google_GAL:
On
Apple_DIO:
On
SDS_Region_Flag:
no_region
Privacy_WithPINRequest:
0
Phone_HMI_Privacy:
0
Hybrid_Radio_additional_online_data:
Not activated
media_control:
Not activated
UOTA:
Off
WiFi_Client_HMI:
Off
RSE_software_component:
activated
Mirror_link:
On
Smartphone_interface_for_rhmi:
activated
sd_slot_deactivation:
no restriction
map_sms_support:
Off
map_email_support:
Off
map_instant_messaging_support:
Off
sim_data_only_sms_support:
Off
esim_data_only_sms_support:
Off
allow_message_editing:
Off
vehicle_readiness_sound:
Not activated
MirrorLink_Country_Code:
MIB_EU
vehicle_leaving_sound:
Not activated
MirrorLink_RGB_Preference:
RGB565
conditioning_variant:
0
Map_Style:
0
Hybrid_Radio_Range_Extender:
deactivated
scon_telephony:
Not activated
voice_over_lte:
Not activated
show_volte_hmi_switch:
Not activated
online_radio:
deactivated
wlan_5ghz_switch:
Not activated
unblock_functions_while_piloted_driving:
blocked
block_hmi_function_p_epb:
blocked
Popup_if_GPS_services_in_use:
Not activated
Baidu_Car_Life_ios:
Off
Tencent_myCar_canceling_share_location:
Off
UOTA_2:
Off
Pilot_Parking:
Not activated
perso_v_threshold:
0
perso_v_threshold_hysteresis:
0
FoD:
SWaP
Baidu_Car_Life_Wireless:
Off
Baidu_Car_Life_ios_Wireless:
Off
Google_GAL_Wireless:
Off
Apple_DIO_Wireless:
Off
rvc_low_black_screen_velocity_threshold:
Not activated
rvc_low_failsafe:
Not activated
rvc_low_black_screen_trunk_open:
Not activated
Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation:
040152045210524052320064009600A401C80082001400140014001400FFFFFFFFFFFFFFFF010005
Radio_Level_Quality_Offsets:
Set_AM_Quality_Level_Offset:
0
Set_FM_Quality_Level_Offset:
0
Bluetooth_Phonebook_Access_Profile:
PBAP
Summertime-automatic:
Manual
Car_Function_Adaptations_Gen2:
menu_display_ACC:
Not activated
menu_display_ACC_operation_clamp_15_off:
Not activated
menu_display_ACC_over_threshold_high:
Not activated
menu_display_ACC_standstill:
Not activated
menu_display_ACC_after_disclaimer:
Not activated
menu_display_ambient_illumination:
activated
menu_display_ambient_illumination_clamp_15_off:
Not activated
menu_display_ambient_illumination_over_threshold_high:
activated
menu_display_ambient_illumination_standstill:
Not activated
menu_display_ambient_illumination_after_disclaimer:
Not activated
menu_display_pdc:
activated
menu_display_pdc_clamp_15_off:
Not activated
menu_display_pdc_over_threshold_high:
activated
menu_display_pdc_standstill:
Not activated
menu_display_pdc_after_disclaimer:
Not activated
menu_display_awv:
activated
menu_display_awv_clamp_15_off:
Not activated
menu_display_awv_over_threshold_high:
activated
menu_display_awv_standstill:
Not activated
menu_display_awv_after_disclaimer:
Not activated
menu_display_Lane_Departure_Warning:
Not activated
menu_display_Lane_Departure_Warning_clamp_15_off:
Not activated
menu_display_Lane_Departure_Warning_over_threshold_high:
Not activated
menu_display_Lane_Departure_Warning_standstill:
Not activated
menu_display_Lane_Departure_Warning_after_disclaimer:
Not activated
menu_display_lane_assistant:
Not activated
menu_display_lane_assistant_clamp_15_off:
Not activated
menu_display_lane_assistant_over_threshold_high:
Not activated
menu_display_lane_assistant_standstill:
Not activated
menu_display_lane_assistant_after_disclaimer:
Not activated
menu_display_exterior_illumination:
activated
menu_display_exterior_illumination_clamp_15_off:
Not activated
menu_display_exterior_illumination_over_threshold_high:
activated
menu_display_exterior_illumination_standstill:
Not activated
menu_display_exterior_illumination_after_disclaimer:
Not activated
menu_display_windows:
activated
menu_display_windows_clamp_15_off:
Not activated
menu_display_windows_over_threshold_high:
activated
menu_display_windows_standstill:
Not activated
menu_display_windows_after_disclaimer:
Not activated
menu_display_clima_configuration:
Not activated
menu_display_clima_configuration_clamp_15_off:
Not activated
menu_display_clima_configuration_over_threshold_high:
Not activated
menu_display_clima_configuration_standstill:
Not activated
menu_display_clima_configuration_after_disclaimer:
Not activated
menu_display_auxiliary_heating:
Not activated
menu_display_auxiliary_heating_clamp_15_off:
Not activated
menu_display_auxiliary_heating_over_threshold_high:
Not activated
menu_display_auxiliary_heating_standstill:
Not activated
menu_display_auxiliary_heating_after_disclaimer:
Not activated
menu_display_board_computer:
activated
menu_display_board_computer_clamp_15_off:
Not activated
menu_display_board_computer_over_threshold_high:
activated
menu_display_board_computer_standstill:
Not activated
menu_display_board_computer_after_disclaimer:
Not activated
menu_display_rdk:
activated
menu_display_rdk_clamp_15_off:
Not activated
menu_display_rdk_over_threshold_high:
activated
menu_display_rdk_standstill:
Not activated
menu_display_rdk_after_disclaimer:
Not activated
menu_display_wiper:
activated
menu_display_wiper_clamp_15_off:
Not activated
menu_display_wiper_over_threshold_high:
activated
menu_display_wiper_standstill:
Not activated
menu_display_wiper_after_disclaimer:
Not activated
menu_display_sia:
activated
menu_display_sia_clamp_15_off:
Not activated
menu_display_sia_over_threshold_high:
activated
menu_display_sia_standstill:
Not activated
menu_display_sia_after_disclaimer:
Not activated
menu_display_seat_configuration:
Not activated
menu_display_seat_configuration_clamp_15_off:
Not activated
menu_display_seat_configuration_over_threshold_high:
Not activated
menu_display_seat_configuration_standstill:
Not activated
menu_display_seat_configuration_after_disclaimer:
Not activated
menu_display_central_locking:
activated
menu_display_central_locking_clamp_15_off:
Not activated
menu_display_central_locking_over_threshold_high:
activated
menu_display_central_locking_standstill:
Not activated
menu_display_central_locking_after_disclaimer:
Not activated
menu_display_compass:
Not activated
menu_display_compass_clamp_15_off:
Not activated
menu_display_compass_over_threshold_high:
Not activated
menu_display_compass_standstill:
Not activated
menu_display_compass_after_disclaimer:
Not activated
menu_display_charisma:
Not activated
menu_display_charisma_clamp_15_off:
Not activated
menu_display_charisma_over_threshold_high:
Not activated
menu_display_charisma_standstill:
Not activated
menu_display_charisma_after_disclaimer:
Not activated
menu_display_oil_level:
Not activated
menu_display_oil_level_clamp_15_off:
Not activated
menu_display_oil_level_over_threshold_high:
Not activated
menu_display_oil_level_standstill:
Not activated
menu_display_oil_level_after_disclaimer:
Not activated
menu_display_vin:
activated
menu_display_vin_clamp_15_off:
Not activated
menu_display_vin_over_threshold_high:
activated
menu_display_vin_standstill:
Not activated
menu_display_vin_after_disclaimer:
Not activated
menu_display_clock:
activated
menu_display_clock_clamp_15_off:
Not activated
menu_display_clock_over_threshold_high:
activated
menu_display_clock_standstill:
Not activated
menu_display_clock_after_disclaimer:
Not activated
menu_display_air_damper:
Not activated
menu_display_air_damper_clamp_15_off:
Not activated
menu_display_air_damper_over_threshold_high:
Not activated
menu_display_air_damper_standstill:
Not activated
menu_display_air_damper_after_disclaimer:
Not activated
menu_display_headup_display:
Not activated
menu_display_headup_display_clamp_15_off:
Not activated
menu_display_headup_display_over_threshold_high:
Not activated
menu_display_headup_display_standstill:
Not activated
menu_display_headup_display_after_disclaimer:
Not activated
menu_display_central_unit_master:
activated
menu_display_central_unit_master_clamp_15_off:
Not activated
menu_display_central_unit_master_over_threshold_high:
activated
menu_display_central_unit_master_standstill:
Not activated
menu_display_central_unit_master_after_disclaimer:
Not activated
menu_display_hybrid:
Not activated
menu_display_hybrid_clamp_15_off:
Not activated
menu_display_hybrid_over_threshold_high:
Not activated
menu_display_hybrid_standstill:
Not activated
menu_display_hybrid_after_disclaimer:
Not activated
menu_display_ugdo:
Not activated
menu_display_ugdo_clamp_15_off:
Not activated
menu_display_ugdo_over_threshold_high:
Not activated
menu_display_ugdo_standstill:
Not activated
menu_display_ugdo_after_disclaimer:
Not activated
menu_display_night_vision:
Not activated
menu_display_night_vision_clamp_15_off:
Not activated
menu_display_night_vision_over_threshold_high:
Not activated
menu_display_night_vision_standstill:
Not activated
menu_display_night_vision_after_disclaimer:
Not activated
menu_display_side_view:
Not activated
menu_display_side_view_clamp_15_off:
Not activated
menu_display_side_view_over_threshold_high:
Not activated
menu_display_side_view_standstill:
Not activated
menu_display_side_view_after_disclaimer:
Not activated
menu_display_reversible_belt_pre_load:
Not activated
menu_display_reversible_belt_pre_load_clamp_15_off:
Not activated
menu_display_reversible_belt_pre_load_over_threshold_high:
Not activated
menu_display_reversible_belt_pre_load_standstill:
Not activated
menu_display_reversible_belt_pre_load_after_disclaimer:
Not activated
menu_display_MFL_jocker:
Not activated
menu_display_MFL_jocker_clamp_15_off:
Not activated
menu_display_MFL_jocker_over_threshold_high:
Not activated
menu_display_MFL_jocker_standstill:
Not activated
menu_display_MFL_jocker_after_disclaimer:
Not activated
menu_display_road_sign_identification:
Not activated
menu_display_road_sign_identification_clamp_15_off:
Not activated
menu_display_road_sign_identification_over_threshold_high:
Not activated
menu_display_road_sign_identification_standstill:
Not activated
menu_display_road_sign_identification_after_disclaimer:
Not activated
menu_display_attention_identification:
Not activated
menu_display_attention_identification_clamp_15_off:
Not activated
menu_display_attention_identification_over_threshold_high:
Not activated
menu_display_attention_identification_standstill:
Not activated
menu_display_attention_identification_after_disclaimer:
Not activated
menu_display_adaptive_key:
Not activated
menu_display_adaptive_key_clamp_15_off:
Not activated
menu_display_adaptive_key_over_threshold_high:
Not activated
menu_display_adaptive_key_standstill:
Not activated
menu_display_adaptive_key_after_disclaimer:
Not activated
menu_display_car_mirror:
activated
menu_display_car_mirror_clamp_15_off:
Not activated
menu_display_car_mirror_over_threshold_high:
activated
menu_display_car_mirror_standstill:
Not activated
menu_display_car_mirror_after_disclaimer:
Not activated
menu_display_driving_school:
Not activated
menu_display_driving_school_clamp_15_off:
Not activated
menu_display_driving_school_over_threshold_high:
Not activated
menu_display_driving_school_standstill:
Not activated
menu_display_driving_school_after_disclaimer:
Not activated
menu_display_weariness_recognition:
Not activated
menu_display_weariness_recognition_clamp_15_off:
Not activated
menu_display_weariness_recognition_over_threshold_high:
Not activated
menu_display_weariness_recognition_standstill:
Not activated
menu_display_weariness_recognition_after_disclaimer:
Not activated
menu_display_BCmE:
Not activated
menu_display_BCmE_clamp_15_off:
Not activated
menu_display_BCmE_over_threshold_high:
Not activated
menu_display_BCmE_standstill:
Not activated
menu_display_BCmE_after_disclaimer:
Not activated
menu_display_user_eco_rating:
activated
menu_display_user_eco_rating_clamp_15_off:
Not activated
menu_display_user_eco_rating_over_threshold_high:
activated
menu_display_user_eco_rating_standstill:
Not activated
menu_display_user_eco_rating_after_disclaimer:
Not activated
menu_display_Brake_Function:
activated
menu_display_Brake_Function_clamp_15_off:
Not activated
menu_display_Brake_Function_over_threshold_high:
activated
menu_display_Brake_Function_standstill:
Not activated
menu_display_Brake_Function_after_disclaimer:
Not activated
menu_display_Start_Stop_reasons:
activated
menu_display_Start_Stop_reasons_clamp_15_off:
Not activated
menu_display_Start_Stop_reasons_over_threshold_high:
activated
menu_display_Start_Stop_reasons_standstill:
Not activated
menu_display_Start_Stop_reasons_after_disclaimer:
Not activated
menu_display_angle_of_slope:
Not activated
menu_display_angle_of_slope_clamp_15_off:
Not activated
menu_display_angle_of_slope_over_threshold_high:
Not activated
menu_display_angle_of_slope_standstill:
Not activated
menu_display_angle_of_slope_after_disclaimer:
Not activated
menu_display_battery_management:
Not activated
menu_display_battery_management_clamp_15_off:
Not activated
menu_display_battery_management_over_threshold_high:
Not activated
menu_display_battery_management_standstill:
Not activated
menu_display_battery_management_after_disclaimer:
Not activated
menu_display_RearSeatEntertainment:
Not activated
menu_display_RearSeatEntertainment_clamp_15_off:
Not activated
menu_display_RearSeatEntertainment_over_threshold_high:
Not activated
menu_display_RearSeatEntertainment_standstill:
Not activated
menu_display_RearSeatEntertainment_after_disclaimer:
Not activated
menu_display_special_functions:
Not activated
menu_display_special_functions_clamp_15_off:
Not activated
menu_display_special_functions_over_threshold_high:
Not activated
menu_display_special_functions_standstill:
Not activated
menu_display_special_functions_after_disclaimer:
Not activated
menu_display_trailer_assistant:
Not activated
menu_display_trailer_assistant_clamp_15_off:
Not activated
menu_display_trailer_assistant_over_threshold_high:
Not activated
menu_display_trailer_assistant_standstill:
Not activated
menu_display_trailer_assistant_after_disclaimer:
Not activated
menu_display_TV_Tuner:
Not activated
menu_display_TV_Tuner_clamp_15_off:
Not activated
menu_display_TV_Tuner_over_threshold_high:
Not activated
menu_display_TV_Tuner_standstill:
Not activated
menu_display_TV_Tuner_after_disclaimer:
Not activated
menu_auxiliary_climatization:
Not activated
menu_auxiliary_climatization_clamp_15_off:
Not activated
menu_auxiliary_climatization_over_threshold_high:
Not activated
menu_auxiliary_climatization_standstill:
Not activated
menu_auxiliary_climatization_after_disclaimer:
Not activated
menu_display_Pedestrian_Assist:
Not activated
menu_display_Pedestrian_Assist_clamp_15_off:
Not activated
menu_display_Pedestrian_Assist_over_threshold_high:
Not activated
menu_display_Pedestrian_Assist_standstill:
Not activated
menu_display_Pedestrian_Assist_after_disclaimer:
Not activated
menu_display_Seat_Pneumatic:
Not activated
menu_display_Seat_Pneumatic_clamp_15_off:
Not activated
menu_display_Seat_Pneumatic_over_threshold_high:
Not activated
menu_display_Seat_Pneumatic_standstill:
Not activated
menu_display_Seat_Pneumatic_after_disclaimer:
Not activated
menu_display_Curve_Assist:
Not activated
menu_display_Curve_Assist_clamp_15_off:
Not activated
menu_display_Curve_Assist_over_threshold_high:
Not activated
menu_display_Curve_Assist_standstill:
Not activated
menu_display_Curve_Assist_after_disclaimer:
Not activated
menu_display_eCall:
Not activated
menu_display_eCall_clamp_15_off:
Not activated
menu_display_eCall_over_threshold_high:
Not activated
menu_display_eCall_standstill:
Not activated
menu_display_eCall_after_disclaimer:
Not activated
menu_display_ENI:
Not activated
menu_display_ENI_clamp_15_off:
Not activated
menu_display_ENI_over_threshold_high:
Not activated
menu_display_ENI_standstill:
Not activated
menu_display_ENI_after_disclaimer:
Not activated
menu_display_SportHMI:
activated
menu_display_SportHMI_clamp_15_off:
Not activated
menu_display_SportHMI_over_threshold_high:
Not activated
menu_display_SportHMI_standstill:
Not activated
menu_display_SportHMI_after_disclaimer:
Not activated
menu_display_Adblue:
Not activated
menu_display_Adblue_clamp_15_off:
Not activated
menu_display_Adblue_over_threshold_high:
Not activated
menu_display_Adblue_standstill:
Not activated
menu_display_Adblue_after_disclaimer:
Not activated
menu_display_Spoiler:
Not activated
menu_display_Spoiler_clamp_15_off:
Not activated
menu_display_Spoiler_over_threshold_high:
Not activated
menu_display_Spoiler_standstill:
Not activated
menu_display_Spoiler_after_disclaimer:
Not activated
menu_display_Efficiency_Assist:
Not activated
menu_display_Efficiency_Assist_clamp_15_off:
Not activated
menu_display_Efficiency_Assist_over_threshold_high:
Not activated
menu_display_Efficiency_Assist_standstill:
Not activated
menu_display_Efficiency_Assist_after_disclaimer:
Not activated
menu_display_Display_Configuration:
Not activated
menu_display_Display_Configuration_clamp_15_off:
Not activated
menu_display_Display_Configuration_over_threshold_high:
Not activated
menu_display_Display_Configuration_standstill:
Not activated
menu_display_Display_Configuration_after_disclaimer:
Not activated
menu_soundcontrol:
Not activated
menu_soundcontrol_clamp_15_off:
Not activated
menu_soundcontrol_over_threshold_high:
Not activated
menu_soundcontrol_standstill:
Not activated
menu_soundcontrol_after_disclaimer:
Not activated
menu_auxiliary_ventilation:
Not activated
menu_auxiliary_ventilation_clamp_15_off:
Not activated
menu_auxiliary_ventilation_over_threshold_high:
Not activated
menu_auxiliary_ventilation_standstill:
Not activated
menu_auxiliary_ventilation_after_disclaimer:
Not activated
menu_crossroad_assistent:
Not activated
menu_crossroad_assistent_clamp_15_off:
Not activated
menu_crossroad_assistent_over_threshold_high:
Not activated
menu_crossroad_assistent_standstill:
Not activated
menu_crossroad_assistent_after_disclaimer:
Not activated
Car_Function_List_CAN_Gen2:
MFL:
available
MFL_msg_bus:
Comfort data bus
reserved:
Not available
reserved_1:
Comfort data bus
Oil_level:
Not available
Oil_level_msg_bus:
Databus drivetrain
PDC_audio_lowering:
available
PDC_audio_lowering_msg_bus:
Suspension data bus
VIN:
available
VIN_msg_bus:
Comfort data bus
Driving_school:
Not available
Driving_school_msg_bus:
Comfort data bus
Adaptive_key_msg_bus:
Comfort data bus
Adaptive_key:
Not available
reserved_2:
Comfort data bus
reserved_3:
Not available
Car_Function_List_BAP_Gen2:
climatic_master_0x01:
Not activated
climatic_master_0x01_msg_bus:
Comfort data bus
climatic_slave_0x02:
Not activated
climatic_slave_0x02_msg_bus:
Comfort data bus
auxilary_heating_0x03:
Not activated
auxilary_heating_0x03_msg_bus:
Comfort data bus
headup_displ_0x04:
Not activated
headup_displ_0x04_msg_bus:
Comfort data bus
ACC_0x05:
Not activated
ACC_0x05_msg_bus:
Terminal 15
air_suspension_0x06:
Not activated
air_suspension_0x06_msg_bus:
Suspension data bus
tire_pressure_system_0x07:
activated
tire_pressure_system_0x07_msg_bus:
Databus drivetrain
interieur_light_0x08:
activated
interieur_light_0x08_msg_bus:
Comfort data bus
exterieur_light_0x09:
activated
exterieur_light_0x09_msg_bus:
Comfort data bus
parking_assist_0x0A:
activated
parking_assist_0x0A_msg_bus:
Terminal 15
VPS_0x0B:
Not activated
VPS_0x0B_msg_bus:
Comfort data bus
wiper_comfort_0x0C:
activated
wiper_comfort_0x0C_msg_bus:
Comfort data bus
central_locking_0x0D:
activated
central_locking_0x0D_msg_bus:
Comfort data bus
mirror_0x0E:
activated
mirror_0x0E_msg_bus:
Comfort data bus
MFA_0x0F:
activated
MFA_0x0F_msg_bus:
Comfort data bus
driver_seat_0x10:
Not activated
driver_seat_0x10_msg_bus:
Comfort data bus
clock_0x11:
activated
clock_0x11_msg_bus:
Comfort data bus
service_interval_display_0x12:
activated
service_interval_display_0x12_msg_bus:
Comfort data bus
unit_master_0x13:
activated
unit_master_0x13_msg_bus:
Comfort data bus
UGDO_0x14:
Not activated
UGDO_0x14_msg_bus:
Terminal 15
compass_0x15:
Not activated
compass_0x15_msg_bus:
Not activated
clima_slave_2_0x16:
Not activated
clima_slave_2_0x16_msg_bus:
Comfort data bus
charisma_0x17:
Not activated
charisma_0x17_msg_bus:
Comfort data bus
Night_Vision_0x18:
Not activated
Night_Vision_0x18_msg_bus:
Not activated
LDW_HCA_0x19:
Not activated
LDW_HCA_0x19_msg_bus:
Databus extended
SWA_0x1A:
Not activated
SWA_0x1A_msg_bus:
Databus extended
AWV_0x1B:
activated
AWV_0x1B_msg_bus:
Terminal 15
Hybrid_0x1D:
Not activated
Hybrid_0x1D_msg_bus:
Databus drivetrain
SideView_0x1E:
Not activated
SideView_0x1E_msg_bus:
Not activated
Reversible_Seat_Belt_Tightener_0x1F:
Not activated
Reversible_Seat_Belt_Tightener_0x1F_msg_bus:
Databus drivetrain
Passanger_Seat_0x20:
Not activated
Passanger_Seat_0x20_msg_bus:
Comfort data bus
traffic_sign_recognition_0x21:
Not activated
traffic_sign_recognition_0x21_msg_bus:
Databus extended
weariness_rcognition_0x22:
Not activated
weariness_rcognition_0x22_msg_bus:
Comfort data bus
BCmE_0x23:
Not activated
BCmE_0x23_msg_bus:
Comfort data bus
Brake_0x26:
activated
Brake_0x26_msg_bus:
Databus drivetrain
Start_Stop_reasons_0x27:
activated
Start_Stop_reasons_0x27_msg_bus:
Comfort data bus
Amplifier_0x2D:
activated
Amplifier_0x2D_msg_bus:
Comfort data bus
TV_tuner_0x2C:
Not activated
TV_tuner_0x2C_msg_bus:
Comfort data bus
RearSeatEntertainment_0x2E:
Not activated
RearSeatEntertainment_0x2E_msg_bus:
Comfort data bus
MFL_Jocker_0x34:
Not activated
MFL_Jocker_msg_bus_0x34:
Comfort data bus
Special_Functions_0x35:
Not activated
Special_Functions_msg_bus_0x35:
Comfort data bus
Trailer_Assistant_0x36:
Not activated
Trailer_Assistant_msg_bus_0x36:
Comfort data bus
ExBoxM2_0x38:
Not activated
Range_Data_0x39:
Not activated
Range_Data_msg_bus_0x39:
Comfort data bus
Angle_Of_Slope_0x24:
Not activated
Angle_Of_Slope_0x24_msg_bus:
Not activated
Battery_Management_0x25:
Not activated
Battery_Management_0x25_msg_bus:
Databus drivetrain
eCall_0x33:
Not activated
eCall_0x33_msg_bus:
Comfort data bus
ENI_0x37:
Not activated
ENI_0x37_msg_bus:
Comfort data bus
Pedestrian_Assist_0x3A:
Not activated
Pedestrian_Assist_msg_bus_0x3A:
Databus extended
Seat_Pneumatic_0x3B:
Not activated
Seat_Pneumatic_msg_bus_0x3B:
Comfort data bus
efficiency_assist_0x3C:
Not activated
efficiency_assis_msg_bus_0x3C:
Comfort data bus
Seatmemory_driver_rear_0x3E:
Not activated
Seatmemory_driver_rear_msg_bus_0x3E:
Comfort data bus
Seatmemory_codriver_rear_0x3F:
Not activated
Seatmemory_codriver_rear_msg_bus_0x3F:
Comfort data bus
ExBoxM2_0x38_msg_bus:
Comfort data bus
5E02A111F2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Number 1 (roaming) for roadside assistance:
Activating and deactivating all development messages:
Infotainment_CAN_Messages:
Off
MIB_CAN_Messages:
Off
Menu entries for mobile online services:
Not activated
Interface for external media, activation:
Connection 1:
activated
Connection 2:
Not activated
Connection 3:
Not activated
Connection 4:
Not activated
Audio Management Input Gain Generation 2:
TV tuner:
-128
Radio (FM):
-128
Radio (AM):
-128
Digital radio (DAB):
-128
Satellite radio:
5
Tuner_TI:
-128
Media_AUXIN:
-128
Media_AUX_Adapter:
-128
Media_CDA:
-128
Media_DVD:
-128
Media_MFP:
-128
Media_BTDevice:
-128
TA_Tuner_FM:
-128
Media_Bluray:
-128
Media_HDMI:
-128
Tuner_Online:
-128
Media_Airplay:
-128
Media_UPNP:
-128
Media_Cloud:
-128
Tuner_Personal:
-128
Tone_Beep:
-128
Tone_Warning:
-128
Tone_Touchscreen:
6
Tone_Messaging:
-128
Exbox_DMB:
-128
Mirrorlink:
-128
TTS_Nav:
-128
TTS_SDS:
-128
Phone_Voice:
-128
Phone_Ringer_MFP:
-128
Phone_Ringer_OB:
-3
HFP:
-128
TV_AV_IN:
-128
Country identification, country of sale HMI:
IE
Locked menu contents:
FB_TUNER_0:
non_blocked
FB_TUNER_1:
non_blocked
FB_TUNER_2:
non_blocked
FB_TUNER_3:
non_blocked
FB_TUNER_4:
non_blocked
FB_TUNER_5:
non_blocked
FB_TUNER_6:
non_blocked
FB_TUNER_7:
non_blocked
FB_TUNER_8:
non_blocked
FB_TUNER_9:
non_blocked
FB_TUNER_10:
non_blocked
FB_TUNER_11:
non_blocked
FB_TUNER_12:
non_blocked
FB_TUNER_13:
non_blocked
FB_TUNER_14:
non_blocked
FB_TUNER_15:
non_blocked
FB_MEDIA_0:
non_blocked
FB_MEDIA_1:
non_blocked
FB_MEDIA_2:
non_blocked
FB_MEDIA_3:
non_blocked
FB_MEDIA_4:
non_blocked
FB_MEDIA_5:
non_blocked
FB_MEDIA_6:
non_blocked
FB_MEDIA_7:
non_blocked
FB_MEDIA_8:
non_blocked
FB_MEDIA_9:
non_blocked
FB_MEDIA_10:
non_blocked
FB_MEDIA_11:
non_blocked
FB_MEDIA_12:
non_blocked
FB_MEDIA_13:
non_blocked
FB_MEDIA_14:
non_blocked
FB_MEDIA_15:
non_blocked
FB_MEDIA_16:
non_blocked
FB_MEDIA_17:
non_blocked
FB_MEDIA_18:
non_blocked
FB_MEDIA_19:
non_blocked
FB_MEDIA_20:
non_blocked
FB_MEDIA_21:
non_blocked
FB_MEDIA_22:
non_blocked
FB_MEDIA_23:
non_blocked
FB_PHONE_0:
non_blocked
FB_PHONE_1:
non_blocked
FB_PHONE_2:
non_blocked
FB_PHONE_3:
non_blocked
FB_PHONE_4:
non_blocked
FB_PHONE_5:
non_blocked
FB_PHONE_6:
non_blocked
FB_PHONE_7:
non_blocked
FB_PHONE_8:
non_blocked
FB_PHONE_9:
non_blocked
FB_PHONE_10:
non_blocked
FB_PHONE_11:
non_blocked
FB_PHONE_12:
non_blocked
FB_PHONE_13:
non_blocked
FB_PHONE_14:
non_blocked
FB_PHONE_15:
non_blocked
FB_NAV_0:
non_blocked
FB_NAV_1:
non_blocked
FB_NAV_2:
non_blocked
FB_NAV_3:
non_blocked
FB_NAV_4:
non_blocked
FB_NAV_5:
non_blocked
FB_NAV_6:
non_blocked
FB_NAV_7:
non_blocked
FB_NAV_8:
non_blocked
FB_NAV_9:
non_blocked
FB_NAV_10:
non_blocked
FB_NAV_11:
non_blocked
FB_NAV_12:
non_blocked
FB_NAV_13:
non_blocked
FB_NAV_14:
non_blocked
FB_NAV_15:
non_blocked
FB_NAV_16:
non_blocked
FB_NAV_17:
non_blocked
FB_NAV_18:
non_blocked
FB_NAV_19:
non_blocked
FB_NAV_20:
non_blocked
FB_NAV_21:
non_blocked
FB_NAV_22:
non_blocked
FB_NAV_23:
non_blocked
FB_NAV_24:
non_blocked
FB_NAV_25:
non_blocked
FB_NAV_26:
non_blocked
FB_NAV_27:
non_blocked
FB_NAV_28:
non_blocked
FB_NAV_29:
non_blocked
FB_NAV_30:
non_blocked
FB_NAV_31:
non_blocked
FB_NAV_32:
non_blocked
FB_NAV_33:
non_blocked
FB_NAV_34:
non_blocked
FB_NAV_35:
non_blocked
FB_NAV_36:
non_blocked
FB_NAV_37:
non_blocked
FB_NAV_38:
non_blocked
FB_NAV_39:
non_blocked
FB_CAR_0:
non_blocked
FB_CAR_1:
non_blocked
FB_CAR_2:
non_blocked
FB_CAR_3:
non_blocked
FB_CAR_4:
non_blocked
FB_CAR_5:
non_blocked
FB_CAR_6:
non_blocked
FB_CAR_7:
non_blocked
FB_CAR_8:
non_blocked
FB_CAR_9:
non_blocked
FB_CAR_10:
non_blocked
FB_CAR_11:
non_blocked
FB_CAR_12:
non_blocked
FB_CAR_13:
non_blocked
FB_CAR_14:
non_blocked
FB_CAR_15:
non_blocked
FB_CAR_16:
non_blocked
FB_CAR_17:
non_blocked
FB_CAR_18:
non_blocked
FB_CAR_19:
non_blocked
FB_CAR_20:
non_blocked
FB_CAR_21:
non_blocked
FB_CAR_22:
non_blocked
FB_CAR_23:
non_blocked
FB_MISC_0:
non_blocked
FB_MISC_1:
non_blocked
FB_MISC_2:
non_blocked
FB_MISC_3:
non_blocked
FB_MISC_4:
non_blocked
FB_MISC_5:
non_blocked
FB_MISC_6:
non_blocked
FB_MISC_7:
non_blocked
FB_MISC_8:
non_blocked
FB_MISC_9:
non_blocked
FB_MISC_10:
non_blocked
FB_MISC_11:
non_blocked
FB_MISC_12:
non_blocked
FB_MISC_13:
non_blocked
FB_MISC_14:
non_blocked
FB_MISC_15:
non_blocked
FB_MISC_16:
non_blocked
FB_MISC_17:
non_blocked
FB_MISC_18:
non_blocked
FB_MISC_19:
non_blocked
FB_MISC_20:
non_blocked
FB_MISC_21:
non_blocked
FB_MISC_22:
non_blocked
FB_MISC_23:
non_blocked
FB_MISC_24:
non_blocked
FB_MISC_25:
non_blocked
FB_MISC_26:
non_blocked
FB_MISC_27:
non_blocked
FB_MISC_28:
non_blocked
FB_MISC_29:
non_blocked
FB_MISC_30:
non_blocked
FB_MISC_31:
non_blocked
FB_MISC_32:
non_blocked
FB_MISC_33:
non_blocked
FB_MISC_34:
non_blocked
FB_MISC_35:
non_blocked
FB_MISC_36:
non_blocked
FB_MISC_37:
non_blocked
FB_MISC_38:
non_blocked
FB_MISC_39:
non_blocked
FB_MISC_40:
non_blocked
FB_MISC_41:
non_blocked
FB_MISC_42:
non_blocked
FB_MISC_43:
non_blocked
FB_MISC_44:
non_blocked
FB_MISC_45:
non_blocked
FB_MISC_46:
non_blocked
FB_MISC_47:
non_blocked
Key_code_monitoring:
monitoring_keycode_0x00_0x07:
ff
monitoring_keycode_0x08_0x0F:
ff
monitoring_keycode_0x10_0x17:
ff
monitoring_keycode_0x18_0x1F:
ff
monitoring_keycode_0x20_0x27:
ff
monitoring_keycode_0x28_0x2F:
ff
monitoring_keycode_0x30_0x37:
ff
monitoring_keycode_0x38_0x3F:
ff
monitoring_keycode_0x40_0x47:
ff
monitoring_keycode_0x48_0x4F:
ff
monitoring_keycode_0x50_0x57:
ff
monitoring_keycode_0x58_0x5F:
ff
monitoring_keycode_0x60_0x67:
ff
monitoring_keycode_0x68_0x6F:
ff
monitoring_keycode_0x70_0x77:
ff
monitoring_keycode_0x78_0x7F:
ff
monitoring_keycode_0x80_0x87:
ff
monitoring_keycode_0x88_0x8F:
ff
monitoring_keycode_0x90_0x97:
ff
monitoring_keycode_0x98_0x9F:
ff
monitoring_keycode_0xA0_0xA7:
ff
monitoring_keycode_0xA8_0xAF:
ff
monitoring_keycode_0xB0_0xB7:
ff
monitoring_keycode_0xB8_0xBF:
ff
monitoring_keycode_0xC0_0xC7:
ff
monitoring_keycode_0xC8_0xCF:
ff
monitoring_keycode_0xD0_0xD7:
ff
monitoring_keycode_0xD8_0xDF:
ff
monitoring_keycode_0xE0_0xE7:
ff
monitoring_keycode_0xE8_0xEF:
ff
monitoring_keycode_0xF0_0xF7:
ff
monitoring_keycode_0xF8_0xFF:
ff
Roller test bench mode, functional:
Not activated
Posted: Sun Nov 01, 2020 12:21 am
by massimo23
For 19 Gateway:
Control unit: 19 Gateway
System description: GW MQB A0
Software number: 6C0909901A
Software version: 0093
Hardware number: 6C0937089
Hardware version: H10
ODX name: EV_GatewA0Lear
ODX version: 013020
Backup name: Gateaway
Long coding:
Sollverbau_MFL:
installed
EHR_EHRPsd15ProviderVerbaut_CO:
not installed
EHR_Funktion:
not active
EM_Ref_Spannungsmessung_Inaktiv:
Yes
HV-EM_Klima_Codierung:
0
MKE_Funktion:
active
EM_Batterie_Verbauort:
10
EM_Generator_Uebersetzung:
64
FPA_Taster_Auswertung:
Rising slope
MKE_Variante:
1
Subsystems:
Subsystem: E221__MFL-TAT
Long coding: 280000
Adaptations:
Installation list, specified installations:
Gateway:
coded
Node_0x01:
Not coded
Node_0x02:
Not coded
Node_0x03:
Not coded
Node_0x04:
Not coded
Node_0x05:
Not coded
Node_0x06:
Not coded
Node_0x07:
Not coded
Node_0x08:
Not coded
Multifunction Module:
Not coded
Parking Assistance:
coded
Tire Pressure Monitoring 1:
Not coded
Steering Column Electronics:
Not coded
Node_0x0D:
Not coded
Central Electrics:
coded
All Wheel Control:
Not coded
Node_0x11:
Not coded
Steering Assistance:
coded
Brakes 1:
coded
Dash Board:
coded
Airbag:
coded
Node_0x16:
Not coded
Node_0x17:
Not coded
Radio:
Not coded
Air Conditioning Compressor:
Not coded
Node_0x1A:
Not coded
Head Up Display:
Not coded
Actuator For Structure-Borne Sound:
Not coded
Node_0x1D:
Not coded
Lock Electronics:
Not coded
Node_0x1F:
Not coded
Node_0x20:
Not coded
Node_0x21:
Not coded
Node_0x22:
Not coded
Deck Lid Control Unit:
Not coded
Node_0x24:
Not coded
Node_0x25:
Not coded
Node_0x26:
Not coded
Node_0x27:
Not coded
Node_0x28:
Not coded
Node_0x29:
Not coded
Node_0x2A:
Not coded
Special Function 2:
Not coded
Special Function:
Not coded
Electronic Roof Control:
Not coded
Node_0x2E:
Not coded
Node_0x2F:
Not coded
High Beam Assistance:
Not coded
Steering Column Locking:
Not coded
Access Startsystem Interface:
Not coded
Sliding Door Rear Left:
Not coded
Sliding Door Rear Right:
Not coded
Node_0x35:
Not coded
Node_0x36:
Not coded
Node_0x37:
Not coded
Node_0x38:
Not coded
Node_0x39:
Not coded
Node_0x3A:
Not coded
Brake Boost:
Not coded
Node_0x3C:
Not coded
Node_0x3D:
Not coded
Door Electronics Rear Driver Side:
Not coded
Door Electronics Rear Passenger Side:
Not coded
Node_0x40:
Not coded
Node_0x41:
Not coded
Thermal Management:
Not coded
Node_0x43:
Not coded
Battery Charger Control Module:
Not coded
Node_0x45:
Not coded
Air Conditioning:
coded
Trailer Function:
Not coded
Node_0x48:
Not coded
Node_0x49:
Not coded
Door Electronics Driver Side:
Not coded
Door Electronics Passenger Side:
Not coded
Seat Adjustment Driver Side:
Not coded
Seat Adjustment Passenger Side:
Not coded
Lane Change Assistant:
Not coded
Front Sensors Driver Assistance System:
Not coded
Vehicle Position Detection:
Not coded
Node_0x51:
Not coded
Node_0x52:
Not coded
Node_0x53:
Not coded
Headlight Regulation:
Not coded
Node_0x55:
Not coded
Node_0x56:
Not coded
Adaptive Cruise Control:
coded
Node_0x58:
Not coded
Node_0x59:
Not coded
Node_0x5A:
Not coded
Node_0x5B:
Not coded
Node_0x5C:
Not coded
Node_0x5D:
Not coded
Node_0x5E:
Not coded
Node_0x5F:
Not coded
Node_0x60:
Not coded
Node_0x61:
Not coded
Node_0x62:
Not coded
Microphone Control Unit:
Not coded
Actuator For Exterior Noise:
Not coded
High Voltage Battery Charge Management:
Not coded
Node_0x66:
Not coded
Telematics Communication Unit:
Not coded
Node_0x68:
Not coded
Camera System Rear View:
Not coded
Auxiliary Parking Heater:
Not coded
Node_0x6B:
Not coded
Node_0x6C:
Not coded
TV Tuner:
Not coded
Node_0x6E:
Not coded
Sound System:
coded
Media Player Position 1:
Not coded
Tachograph:
Not coded
Wheel Dampening Electronics:
Not coded
Information Control Unit 1:
coded
Node_0x74:
Not coded
Node_0x75:
Not coded
Engine Control Module 1:
coded
Transmission Control Module:
Not coded
Node_0x78:
Not coded
Node_0x79:
Not coded
Node_0x7A:
Not coded
Battery Energy Control Module:
Not coded
Drive Motor Control Module:
Not coded
Node_0x7D:
Not coded
Node_0x7E:
Not coded
Node_0x7F:
Not coded
Node_0x80:
Not coded
Node_0x81:
Not coded
Node_0x82:
Not coded
Node_0x83:
Not coded
Control Module For Sunroof:
Not coded
Node_0x85:
Not coded
Node_0x86:
Not coded
Node_0x87:
Not coded
Node_0x88:
Not coded
Node_0x89:
Not coded
Control Unit Lane Change Assistant 2:
Not coded
Node_0x8B:
Not coded
Node_0x8C:
Not coded
Node_0x8D:
Not coded
Node_0x8E:
Not coded
Node_0x8F:
Not coded
Node_0x90:
Not coded
Node_0x91:
Not coded
Node_0x92:
Not coded
Node_0x93:
Not coded
Node_0x94:
Not coded
Node_0x95:
Not coded
Node_0x96:
Not coded
Node_0x97:
Not coded
Node_0x98:
Not coded
Node_0x99:
Not coded
Node_0x9A:
Not coded
Node_0x9B:
Not coded
Node_0x9C:
Not coded
Node_0x9D:
Not coded
Node_0x9E:
Not coded
Node_0x9F:
Not coded
Node_0xA0:
Not coded
Node_0xA1:
Not coded
Node_0xA2:
Not coded
Node_0xA3:
Not coded
Auxiliary Air Heater:
Not coded
Node_0xA5:
Not coded
Node_0xA6:
Not coded
Node_0xA7:
Not coded
Node_0xA8:
Not coded
Not coded
Node_0xAA:
Not coded
Node_0xAB:
Not coded
Node_0xAC:
Not coded
Node_0xAD:
Not coded
Battery regulation:
Not coded
Node_0xAF:
Not coded
Node_0xB0:
Not coded
Node_0xB1:
Not coded
Node_0xB2:
Not coded
Node_0xB3:
Not coded
Node_0xB4:
Not coded
Node_0xB5:
Not coded
Node_0xB6:
Not coded
Node_0xB7:
Not coded
Node_0xB8:
Not coded
Node_0xB9:
Not coded
Node_0xBA:
Not coded
Node_0xBB:
Not coded
Node_0xBC:
Not coded
Node_0xBD:
Not coded
Node_0xBE:
Not coded
Node_0xBF:
Not coded
Node_0xC0:
Not coded
Node_0xC1:
Not coded
Node_0xC2:
Not coded
Node_0xC3:
Not coded
Node_0xC4:
Not coded
Node_0xC5:
Not coded
Node_0xC6:
Not coded
Node_0xC7:
Not coded
Node_0xC8:
Not coded
Node_0xC9:
Not coded
Node_0xCA:
Not coded
Node_0xCB:
Not coded
Node_0xCC:
Not coded
Node_0xCD:
Not coded
Node_0xCE:
Not coded
Node_0xCF:
Not coded
Node_0xD0:
Not coded
Node_0xD1:
Not coded
Node_0xD2:
Not coded
Node_0xD3:
Not coded
Node_0xD4:
Not coded
Node_0xD5:
Not coded
Node_0xD6:
Not coded
Node_0xD7:
Not coded
Node_0xD8:
Not coded
Node_0xD9:
Not coded
Node_0xDA:
Not coded
Node_0xDB:
Not coded
Node_0xDC:
Not coded
Node_0xDD:
Not coded
Node_0xDE:
Not coded
Node_0xDF:
Not coded
Node_0xE0:
Not coded
Node_0xE1:
Not coded
Node_0xE2:
Not coded
Node_0xE3:
Not coded
Node_0xE4:
Not coded
Node_0xE5:
Not coded
Node_0xE6:
Not coded
Node_0xE7:
Not coded
Node_0xE8:
Not coded
Node_0xE9:
Not coded
Node_0xEA:
Not coded
Node_0xEB:
Not coded
Node_0xEC:
Not coded
Node_0xED:
Not coded
Node_0xEE:
Not coded
Node_0xEF:
Not coded
Node_0xF0:
Not coded
Node_0xF1:
Not coded
Node_0xF2:
Not coded
Node_0xF3:
Not coded
Node_0xF4:
Not coded
Node_0xF5:
Not coded
Node_0xF6:
Not coded
Node_0xF7:
Not coded
Node_0xF8:
Not coded
Node_0xF9:
Not coded
Node_0xFA:
Not coded
Node_0xFB:
Not coded
Node_0xFC:
Not coded
Node_0xFD:
Not coded
Node_0xFE:
Not coded
Node_0xFF:
Not coded
Battery adaptation:
Rated battery capacity:
59 Ah
Battery manufacturer:
JCB
Battery serial number:
1111111111
Battery technology:
EFB
Static current measuring mode:
Not activated
Transport mode:
not active
Component protection showroom mode:
not active
GW_Enable_CAN_Timeout_DTC:
Gateway:
enabled
Gateway_Component_List_Failure_Mask_Node_0x01:
enabled
Gateway_Component_List_Failure_Mask_Node_0x02:
enabled
Gateway_Component_List_Failure_Mask_Node_0x03:
enabled
Gateway_Component_List_Failure_Mask_Node_0x04:
enabled
Gateway_Component_List_Failure_Mask_Node_0x05:
enabled
Gateway_Component_List_Failure_Mask_Node_0x06:
enabled
Gateway_Component_List_Failure_Mask_Node_0x07:
enabled
Gateway_Component_List_Failure_Mask_Node_0x08:
enabled
Gateway_Component_List_Failure_Mask_Node_0x09:
enabled
Parking Assistance:
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x0D:
enabled
Central Electrics:
enabled
All Wheel Control:
enabled
Gateway_Component_List_Failure_Mask_Node_0x11:
enabled
enabled
Brakes 1:
not enabled
Dash Board:
enabled
Airbag:
not enabled
Gateway_Component_List_Failure_Mask_Node_0x16:
enabled
Gateway_Component_List_Failure_Mask_Node_0x17:
enabled
Radio:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x1A:
enabled
Head Up Display:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x1D:
enabled
Lock Electronics:
enabled
Gateway_Component_List_Failure_Mask_Node_0x1F:
enabled
Gateway_Component_List_Failure_Mask_Node_0x20:
enabled
Gateway_Component_List_Failure_Mask_Node_0x21:
enabled
Gateway_Component_List_Failure_Mask_Node_0x22:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x24:
enabled
Gateway_Component_List_Failure_Mask_Node_0x25:
enabled
Gateway_Component_List_Failure_Mask_Node_0x26:
enabled
Gateway_Component_List_Failure_Mask_Node_0x27:
enabled
Gateway_Component_List_Failure_Mask_Node_0x28:
enabled
Gateway_Component_List_Failure_Mask_Node_0x29:
enabled
Gateway_Component_List_Failure_Mask_Node_0x2A:
enabled
Special Function 2:
enabled
Special Function:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x2E:
enabled
Gateway_Component_List_Failure_Mask_Node_0x2F:
enabled
enabled
enabled
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x35:
enabled
Gateway_Component_List_Failure_Mask_Node_0x36:
enabled
Gateway_Component_List_Failure_Mask_Node_0x37:
enabled
Gateway_Component_List_Failure_Mask_Node_0x38:
enabled
Gateway_Component_List_Failure_Mask_Node_0x39:
enabled
Gateway_Component_List_Failure_Mask_Node_0x3A:
enabled
Brake Boost:
enabled
Gateway_Component_List_Failure_Mask_Node_0x3C:
enabled
Gateway_Component_List_Failure_Mask_Node_0x3D:
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x40:
enabled
Gateway_Component_List_Failure_Mask_Node_0x41:
enabled
Thermal Management:
enabled
Gateway_Component_List_Failure_Mask_Node_0x43:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x45:
enabled
Air Conditioning:
enabled
Trailer Function:
enabled
Gateway_Component_List_Failure_Mask_Node_0x48:
enabled
Gateway_Component_List_Failure_Mask_Node_0x49:
enabled
enabled
enabled
enabled
enabled
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x51:
enabled
Gateway_Component_List_Failure_Mask_Node_0x52:
enabled
Gateway_Component_List_Failure_Mask_Node_0x53:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x55:
enabled
Gateway_Component_List_Failure_Mask_Node_0x56:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x58:
enabled
Gateway_Component_List_Failure_Mask_Node_0x59:
enabled
Gateway_Component_List_Failure_Mask_Node_0x5A:
enabled
Gateway_Component_List_Failure_Mask_Node_0x5B:
enabled
Gateway_Component_List_Failure_Mask_Node_0x5C:
enabled
Gateway_Component_List_Failure_Mask_Node_0x5D:
enabled
Gateway_Component_List_Failure_Mask_Node_0x5E:
enabled
Gateway_Component_List_Failure_Mask_Node_0x5F:
enabled
Gateway_Component_List_Failure_Mask_Node_0x60:
enabled
Gateway_Component_List_Failure_Mask_Node_0x61:
enabled
Gateway_Component_List_Failure_Mask_Node_0x62:
enabled
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x66:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x68:
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x6B:
enabled
Gateway_Component_List_Failure_Mask_Node_0x6C:
enabled
TV Tuner:
enabled
Gateway_Component_List_Failure_Mask_Node_0x6E:
enabled
Sound System:
enabled
enabled
Tachograph:
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x74:
enabled
Gateway_Component_List_Failure_Mask_Node_0x75:
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x78:
enabled
Gateway_Component_List_Failure_Mask_Node_0x79:
enabled
Gateway_Component_List_Failure_Mask_Node_0x7A:
enabled
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x7D:
enabled
Gateway_Component_List_Failure_Mask_Node_0x7E:
enabled
Gateway_Component_List_Failure_Mask_Node_0x7F:
enabled
Gateway_Component_List_Failure_Mask_Node_0x80:
enabled
Gateway_Component_List_Failure_Mask_Node_0x81:
enabled
Gateway_Component_List_Failure_Mask_Node_0x82:
enabled
Gateway_Component_List_Failure_Mask_Node_0x83:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x85:
enabled
Gateway_Component_List_Failure_Mask_Node_0x86:
enabled
Gateway_Component_List_Failure_Mask_Node_0x87:
enabled
Gateway_Component_List_Failure_Mask_Node_0x88:
enabled
Gateway_Component_List_Failure_Mask_Node_0x89:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0x8B:
enabled
Gateway_Component_List_Failure_Mask_Node_0x8C:
enabled
Gateway_Component_List_Failure_Mask_Node_0x8D:
enabled
Gateway_Component_List_Failure_Mask_Node_0x8E:
enabled
Gateway_Component_List_Failure_Mask_Node_0x8F:
enabled
Gateway_Component_List_Failure_Mask_Node_0x90:
enabled
Gateway_Component_List_Failure_Mask_Node_0x91:
enabled
Gateway_Component_List_Failure_Mask_Node_0x92:
enabled
Gateway_Component_List_Failure_Mask_Node_0x93:
enabled
Gateway_Component_List_Failure_Mask_Node_0x94:
enabled
Gateway_Component_List_Failure_Mask_Node_0x95:
enabled
Gateway_Component_List_Failure_Mask_Node_0x96:
enabled
Gateway_Component_List_Failure_Mask_Node_0x97:
enabled
Gateway_Component_List_Failure_Mask_Node_0x98:
enabled
Gateway_Component_List_Failure_Mask_Node_0x99:
enabled
Gateway_Component_List_Failure_Mask_Node_0x9A:
enabled
Gateway_Component_List_Failure_Mask_Node_0x9B:
enabled
Gateway_Component_List_Failure_Mask_Node_0x9C:
enabled
Gateway_Component_List_Failure_Mask_Node_0x9D:
enabled
Gateway_Component_List_Failure_Mask_Node_0x9E:
enabled
Gateway_Component_List_Failure_Mask_Node_0x9F:
enabled
Gateway_Component_List_Failure_Mask_Node_0xA0:
enabled
Gateway_Component_List_Failure_Mask_Node_0xA1:
enabled
Gateway_Component_List_Failure_Mask_Node_0xA2:
enabled
Gateway_Component_List_Failure_Mask_Node_0xA3:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0xA5:
enabled
Gateway_Component_List_Failure_Mask_Node_0xA6:
enabled
Gateway_Component_List_Failure_Mask_Node_0xA7:
enabled
Gateway_Component_List_Failure_Mask_Node_0xA8:
enabled
enabled
Gateway_Component_List_Failure_Mask_Node_0xAA:
enabled
Gateway_Component_List_Failure_Mask_Node_0xAB:
enabled
Gateway_Component_List_Failure_Mask_Node_0xAC:
enabled
Gateway_Component_List_Failure_Mask_Node_0xAD:
enabled
Battery regulation:
enabled
Gateway_Component_List_Failure_Mask_Node_0xAF:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB0:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB1:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB2:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB3:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB4:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB5:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB6:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB7:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB8:
enabled
Gateway_Component_List_Failure_Mask_Node_0xB9:
enabled
Gateway_Component_List_Failure_Mask_Node_0xBA:
enabled
Gateway_Component_List_Failure_Mask_Node_0xBB:
enabled
Gateway_Component_List_Failure_Mask_Node_0xBC:
enabled
Gateway_Component_List_Failure_Mask_Node_0xBD:
enabled
Gateway_Component_List_Failure_Mask_Node_0xBE:
enabled
Gateway_Component_List_Failure_Mask_Node_0xBF:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC0:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC1:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC2:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC3:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC4:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC5:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC6:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC7:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC8:
enabled
Gateway_Component_List_Failure_Mask_Node_0xC9:
enabled
Gateway_Component_List_Failure_Mask_Node_0xCA:
enabled
Gateway_Component_List_Failure_Mask_Node_0xCB:
enabled
Gateway_Component_List_Failure_Mask_Node_0xCC:
enabled
Gateway_Component_List_Failure_Mask_Node_0xCD:
enabled
Gateway_Component_List_Failure_Mask_Node_0xCE:
enabled
Gateway_Component_List_Failure_Mask_Node_0xCF:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD0:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD1:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD2:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD3:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD4:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD5:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD6:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD7:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD8:
enabled
Gateway_Component_List_Failure_Mask_Node_0xD9:
enabled
Gateway_Component_List_Failure_Mask_Node_0xDA:
enabled
Gateway_Component_List_Failure_Mask_Node_0xDB:
enabled
Gateway_Component_List_Failure_Mask_Node_0xDC:
enabled
Gateway_Component_List_Failure_Mask_Node_0xDD:
enabled
Gateway_Component_List_Failure_Mask_Node_0xDE:
enabled
Gateway_Component_List_Failure_Mask_Node_0xDF:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE0:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE1:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE2:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE3:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE4:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE5:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE6:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE7:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE8:
enabled
Gateway_Component_List_Failure_Mask_Node_0xE9:
enabled
Gateway_Component_List_Failure_Mask_Node_0xEA:
enabled
Gateway_Component_List_Failure_Mask_Node_0xEB:
enabled
Gateway_Component_List_Failure_Mask_Node_0xEC:
enabled
Gateway_Component_List_Failure_Mask_Node_0xED:
enabled
Gateway_Component_List_Failure_Mask_Node_0xEE:
enabled
Gateway_Component_List_Failure_Mask_Node_0xEF:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF0:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF1:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF2:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF3:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF4:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF5:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF6:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF7:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF8:
enabled
Gateway_Component_List_Failure_Mask_Node_0xF9:
enabled
Gateway_Component_List_Failure_Mask_Node_0xFA:
enabled
Gateway_Component_List_Failure_Mask_Node_0xFB:
enabled
Gateway_Component_List_Failure_Mask_Node_0xFC:
enabled
Gateway_Component_List_Failure_Mask_Node_0xFD:
enabled
Gateway_Component_List_Failure_Mask_Node_0xFE:
enabled
Gateway_Component_List_Failure_Mask_Node_0xFF:
enabled
Gateway_Component_List_Failure_Mask_Node_0x00:
enabled
GW_mirror_mode:
mirror_mode_bus:
Databus drivetrain
mirror_mode_typ:
not active
MKE Check box:
activated
WakeUpMonitor_Configuration:
Sample_Time_Keeping_Awake_Events:
12 s
Max_Num_Keeping_Awake_Events:
100
WakeUpMonitor_Start_Delay:
0 s
WakeUpMonitor_Activation:
Activation:
activated
Open_Filter_Activate:
Not activated
Distance left for deactivation of static current measuring mode:
2
Distance left for deactivation of transport mode:
50
Activation stages:
Not activated
Malfunction states:
no error
Deactivation of start-stop function:
Mode not active
Auxiliary heater activation restriction request:
Switch_on_ban_activation:
Mode not active
Set_point_target_time:
Energy management deactivation stage:
Mode not active
EM_energy_management_warning_displays:
Generatormeldungen:
Mode not active
Batteriemeldungen:
Mode not active
MMI Vorwarnungen:
Mode not active
Ladezustand:
Mode not active
Energy management heat output control status:
Mode not active
Increase idle speed request:
Mode not active
Battery terminal recognition:
connected
Hysteresis voltage:
Voltage_lowering:
12.1 V
Voltage_elevation:
12.1 V
EM_nominal_voltage_limitation_low_beams:
12.1 V
Generator specified voltage value variable:
Set_point_voltage:
10.6 V
EM_start_stop_requirement_ambient_temperature:
Minimum_temperature:
-50.0 °C
Maximum_temperature:
-50.0 °C
EM_requirement_reduction_air_blowers:
Mode not active
EM_requirement_cyclic_time_voltage_measurement:
0 s
Production mode:
p_mode_deactivate_recuperation:
Deactivating
p_mode_deactivate_mfl_keys:
Deactivating
Development messages:
not active
GW_routing_0:
000000000000000000000000
GW_routing_1:
GW_routing_2:
GW_routing_3:
GW_routing_4:
GW_routing_5:
GW_routing_6:
GW_routing_7:
GW_routing_8:
GW_routing_9:
Driving_Profile_Selection_Parameter:
Driving_Profile_Selection_Toogle_Time_Adaptation:
0 ms
Driving_Profile_Selection_Touch_Contact_Time_Adaption:
0 ms
Driving_Profile_Selection_Indication_Control_Adaption:
0 ms
Driving_Profile_Selection_Kombi_Offset_Adaption:
0 ms
Driving_Profile_Selection_Sync_Time_Adaptation:
1500 ms
Driving_Profile_Selection_Request_Repetition_Time_Adaptation:
180000 ms
Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation:
10000 ms
Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation:
100
Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation:
60000 ms
Driving_Profile_Selection_Counter_Master_Reset:
active
Multi_function_steering_wheel_control_module Coding Value:
Steering wheel tiptronic switch:
not installed
Temperature sensor:
not installed
Version:
CCS
development_1:
active
development_2:
not active
MuFu-variant_Skoda:
not installed
MuFu-variant_Seat:
not installed
Production process data 1:
8000
Counter for inconsistent states:
156
Start/stop start voltage limit:
7.6 V
ffffffff
Cyclization limitation request battery service:
0
EM_heating_power_quota_adjustment:
-1000 W
Re: Beats sound system
Posted: Sun Nov 01, 2020 12:22 am
by massimo23
For 47 Sound System:
Control unit: 47 Sound System
System description: KonzernAmp 8K
Software number: 5Q6035456
Software version: 2426
Hardware number: 5Q6035456
Hardware version: H01
ODX name: EV_AMPCAN8C1PASE
ODX version: 001015
Backup name: Sound system
Long coding:
0202000000AAAA00000000000000
byte_0_brand:
VW
byte_0_brand_sound:
default
byte_1_Car_Class:
2
0
byte_3_Roof_ECU:
No
byte_3_Hood:
hood_close
byte_12_ANC_Microphone_4:
not connected
byte_4_Country:
no_country
byte_10_Channel_24_TT:
not installed
byte_6_Channel_8_TT:
installed
Drive type:
Combustion engine
Adaptations:
4000 Hz
1000 Hz
100 Hz
Electrical test 2 of loudspeakers:
Mode:
automatic
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
33
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
19000 Hz
49
Parameter_AC-Diagnostics_Channel_17_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_17_Test_Volume:
49
Parameter_AC-Diagnostics_Channel_18_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_18_Test_Volume:
49
Parameter_AC-Diagnostics_Channel_19_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_19_Test_Volume:
49
Parameter_AC-Diagnostics_Channel_20_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_20_Test_Volume:
49
Parameter_AC-Diagnostics_Channel_21_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_21_Test_Volume:
49
Parameter_AC-Diagnostics_Channel_22_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_22_Test_Volume:
49
Parameter_AC-Diagnostics_Channel_23_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_23_Test_Volume:
49
Parameter_AC-Diagnostics_Channel_24_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_24_Test_Volume:
49
Posted: Sun Nov 01, 2020 1:31 pm
by J+silva
Thanks for the answer I can not see difference in between yours and mine I think I have to load parameters to beats sound I have no sound in media and radio.
Posted: Sun Nov 01, 2020 3:04 pm
by massimo23
Is the sound system adaption coded in the gateway?
Have you checked setting in 5F infotainment unit?
Posted: Sun Nov 01, 2020 5:21 pm
by J+silva
I can not put it in the 5F sound system external bap because it increases the sound and do not turn down I have tried all the possibilities nothing works I made a retrofit of my radio and update to the latest version and it maybe alter the parameters.
Posted: Mon Nov 02, 2020 6:34 pm
by J+silva
The problem now I have to find some one with vas5054 to load parameter via odis
Posted: Wed Nov 18, 2020 2:23 pm
by J+silva
I had to go to a seat dealer and he put the beats sound parameters and it is now working.
