Intermittent elctrical problem Polo 6R bluemotion
Posted: Wed Nov 25, 2020 2:03 pm
Have an ongoing intermittent issue with my electricals, and hope some one has an ide of what it is or what I can do, this is what happened:
in May, the car would blink as i was driving and all the electrics where shout down for a second and then started up again. no big problem... after a couple of weeks it get worse and it would blink 4-5 times in 10min and then a the red triangle on the dashboard was lighted, the motor was running but the headlights, blinkers, wipers where out and alot of errors was occurred in the screen. If i turned of the engine and started up again the problem was fixed for at least 1min.
I turned in the car to the mechanic, it cost 500 euro but they didnt fix the problem. they didnt get a faultcode.
about a month ago the rear light and blinkers (on the driver side) are not working (almost permanent), the bright side of this is that the old problem is gone but i need to get it fixed.
I have checked all the fuses an its all fine, and found some ground and clean them but i still doesent work, could it be the BCM?
