Engine response question.
Posted: Sat Apr 10, 2021 7:24 pm
by mirceaculita
I may be losing my mind so please bare with me
I've always been a bit annoyed about how slow the engine revs and how hard(at least for me) is to get going from a stand still so I just decided to make this weird post.
Sometimes the engine takes a LONG time to rev. I would floor the accelerator and it would literally take over a second for the engine to do anything, but sometimes(mostly when the engine is cold) it's all fine. The smallest throttle inputs are being registered and the engine revs really nice and quick and the clutch engagement is ON POINT.
I honestly don't know what could possibly cause this. When getting a scan with my buddy's VCDS cable thingy there are no errors, after I get going the car drives fine.
Re: Engine response question.
Posted: Sun Apr 11, 2021 7:30 pm
by amer6R
Petrol or diesel?
Posted: Mon Apr 12, 2021 8:14 am
by mirceaculita
amer6R wrote: Sun Apr 11, 2021 7:30 pm
Petrol or diesel?
1.2 TDI
Posted: Tue Apr 13, 2021 11:07 am
by amer6R
I think turbo actuator, or a clogged egr. If everything else is good.
Does your car smell on oil or diesel?
Posted: Tue Apr 13, 2021 6:38 pm
by mirceaculita
amer6R wrote: Tue Apr 13, 2021 11:07 am
there is no weird smells in or around the car. I'll have a look into checking the turbo actuator and the egr. Thx for your input.
Posted: Tue Oct 25, 2022 3:23 pm
by mirceaculita
Ok, I am going to revive this old thread to explain how I finally fixed the problem
The problem came from the gas pedal. More specifically the gas pedal position sensor that was not calibrated correctly.
I randomly stumbled upon a youtube video showing a guy calibrating his sensor and he did the following:
Hook up a vcds(or anything similar) to the car.
Read the voltage coming of the accelerator pedal sensor. For me when it was not pressed it was about 0.7V.
Start pressing the pedal until the engine speed starts to raise(you can also watch the engine speed value with vcds) and note the voltage at which this happens.(for me it was 0.92V)
Now you can loosen the 3 screws on the side of the pedal and move the sensor until you get to that value and tighten the screws back. Now you have instant response when pressing the pedal.
My problems came from the fact that the first 1-1.5cm of pedal travel the engine would not register anything so it would feel very odd when trying to set off from a stand still.
You can watch the video for a clearer image:
https://www.youtube.com/watch?v=p4BSx0Q ... urDIYneeds
Posted: Tue Oct 25, 2022 6:19 pm
by amer6R
Pretty cool find, i will do this to my car also. I never liked the feel of the accelerator pedal it felt like you have to press it way to much before anything happens
Posted: Wed Oct 26, 2022 3:00 pm
by amer6R
Well on my CAYB the pedal is Hella and not Bosch. The bolt pattern looks a bit different and it uses star and Philips screws.
My default voltage is 0.728V and the default rpms are ~780. They start to grow on .950V
@iichel what is you take on this ?
03L 906 023 D ADVMB 1.6l R4 CR td H13 9970
Marker TIME Loc. IDE00021 TIME Loc. IDE00392-ENG100739
STAMP Engine speed STAMP Accelerator pedal: sensor voltage 1-V_PVS_1_BAS
/min V
0.08 784 0.17 0.728
0.29 777 0.39 0.728
0.51 777 0.6 0.728
0.73 777 0.83 0.771
0.95 785 1.04 0.815
1.16 780 1.26 0.84
1.38 785 1.48 0.859
1.6 780 1.72 0.874
1.83 778 1.94 0.894
2.04 785 2.16 0.898
2.26 779 2.38 0.913
2.48 781 2.6 0.923
2.72 780 2.83 0.933
2.94 781 3.04 0.962
3.16 788 3.26 0.967
3.38 828 3.48 0.972
3.6 859 3.72 0.977
3.83 876 3.94 0.977
4.04 876 4.16 0.972
4.26 874 4.38 0.972
4.48 878 4.6 0.972
4.72 875 4.83 0.972
4.94 873 5.04 0.967
5.16 873 5.26 0.854
5.38 750 5.48 0.728
5.6 741 5.72 0.728
5.83 738 5.94 0.728
6.04 745 6.17 0.728
6.27 751 6.4 0.806
6.52 754 6.64 0.874
6.76 762 6.86 0.894
6.98 756 7.09 0.908
7.2 763 7.3 0.923
7.42 774 7.54 0.938
7.64 777 7.76 0.952
7.86 775 7.98 0.962
8.09 795 8.2 0.967
8.3 849 8.42 0.967
8.52 857 8.63 0.84
8.76 770 8.86 0.728
8.98 736 9.09 0.728
9.2 729 9.3 0.728
9.42 734 9.52 0.728
9.63 743 9.76 0.728
9.86 750 9.98 0.728
10.09 752 10.2 0.801
10.3 759 10.42 0.825
10.52 761 10.64 0.854
10.73 766 10.85 0.859
10.98 769 11.08 0.864
11.2 778 11.3 0.869
11.42 776 11.51 0.884
11.64 783 11.73 0.894
11.85 781 11.98 0.903
12.09 778 12.2 0.908
12.29 776 12.42 0.908
12.51 782 12.63 0.913
12.73 778 12.85 0.913
12.98 779 13.08 0.918
13.19 777 13.29 0.918
13.41 779 13.51 0.918
13.63 777 13.73 0.918
13.85 786 13.98 0.923
14.08 777 14.2 0.933
14.29 776 14.42 0.942
14.51 778 14.63 0.942
14.73 785 14.85 0.942
14.98 785 15.08 0.942
15.2 776 15.29 0.942
15.41 783 15.51 0.942
15.63 771 15.73 0.942
15.85 784 15.98 0.942
16.09 781 16.2 0.938
16.3 776 16.42 0.928
16.51 778 16.64 0.903
16.73 779 16.85 0.903
16.98 786 17.08 0.903
17.2 787 17.29 0.908
17.41 782 17.51 0.918
17.63 776 17.73 0.942
17.85 779 17.94 0.957
18.04 783 18.16 0.962
18.26 821 18.39 0.962
18.49 853 18.59 0.957
18.71 857 18.8 0.918
18.9 801 19.03 0.728
19.13 735 19.25 0.728
19.37 728 19.47 0.728
19.59 740 19.71 0.728
19.84 741 19.96 0.728
20.1 748 20.19 0.815
20.31 755 20.43 0.854
20.55 763 20.68 0.869
20.8 765 20.92 0.874
21.04 773 21.14 0.879
21.26 772 21.36 0.879
21.48 778 21.58 0.884
21.7 778 21.8 0.884
21.91 777 22.04 0.898
22.14 786 22.26 0.908
22.36 782 22.48 0.913
22.59 777 22.7 0.913
22.83 781 22.92 0.913
23.04 780 23.14 0.913
23.26 776 23.36 0.913
23.48 775 23.59 0.918
23.7 778 23.8 0.923
23.91 778 24.04 0.923
24.14 781 24.26 0.923
24.36 783 24.47 0.923
24.6 786 24.73 0.923
24.84 780 24.94 0.923
25.08 780 25.21 0.923
25.3 780 25.43 0.728
25.55 776 25.67 0.728
25.8 778 25.89 0.728
26.01 782 26.11 0.728
26.23 784 26.33 0.728
26.45 782 26.54 0.728
26.66 778 26.76 0.737
26.88 779 26.98 0.811
27.1 781 27.22 0.845
27.33 781 27.44 0.845
27.54 776 27.66 0.854
27.76 779 27.88 0.869
27.98 785 28.1 0.884
28.22 781 28.33 0.894
28.44 780 28.54 0.894
28.66 779 28.76 0.894
28.88 776 28.99 0.894
29.09 778 29.21 0.903
29.3 783 29.44 0.913
29.53 781 29.63 0.918
29.75 779 29.86 0.918
29.99 782 30.07 0.918
30.19 783 30.32 0.918
30.45 783 30.55 0.928
30.66 780 30.79 0.933
30.9 783 31.03 0.933
31.13 782 31.27 0.938
31.36 782 31.46 0.938
31.6 784 31.68 0.938
31.8 776 31.9 0.938
32.02 774 32.12 0.942
32.24 784 32.35 0.952
32.46 787 32.55 0.957
32.68 795 32.77 0.957
32.9 822 32.99 0.957
33.09 826 33.18 0.957
33.3 833 33.41 0.957
33.54 831 33.63 0.742
33.75 731 33.86 0.728
Posted: Wed Oct 26, 2022 5:51 pm
by iichel
Very interesting. I'm used to the gas pedal not responding 'instantaneous' but it's pretty smart to mechanically adjust the sensor/pedal interface.
Posted: Wed Oct 26, 2022 10:29 pm
by mirceaculita
You can see on the bottom right of the picture that the bolts are designed to be loosened and have the sensor adjusted by the elongated hole the screw is in.
